TPA - USB Transport
Hey Folks,
I am in the midst of a job transition. So my focus has to be on making it a smooth one for the next couple of months or so. I am personally disappointed (since I want it too) that this has delayed the project significantly, but first things first, I have to concentrate on what earns me a living.
I do still intend to finish up the project. It just is not as high a personal priority at the moment.
That said. I do have about 5 other very cool new modules done, its just a matter of getting final testing done and stock built up. They had actually been in the works for a long time.
Cheers!
Russ
Not trying to rush you (too much;)) but I am definately interested in the 32bit/384kHz version of the USB board as well..... Hopefully you will be able to work on it and get the project completed soon Russ. Thanks for the time and efforts you put in along with your regular job.
Greg
ATTN RUSS...
hi, no need to respond, I just wanted you to know this. Please be sure to provide the option for an external power supply on the new USB module.
I have just applied an external (regulated and filtered LiFePO4 battery) to my Wavelink (it is designed to run off of USB power) and the perfromance difference is notable. An external supply will also allow you to design beyond the limitations of the USB port, perhaps allowing for the option of Trident(s) onboard for XO supplies, etc.
Any update?
OK, now that the B3 is shipping, is the USB module your next priority, or are there some other little gems you are working on before it? I hate to pester you guys but I'm really hoping this will be available by the time I finnish my B3-IVY3-Sympatico build. The USB board will be the last part in this project.
Cheers
Dan
