900W H-class PA Amp with Limiter
I have not tried.
Because I work with a professional factory amplifiers.But it would be interesting to have an alternative if the some channel burns.
Believe it or not but I have A/B class amplifier DAS Audio E 12,
wit rails supply +/- 120V DC for Mid/Highs speakers, there is no step up voltage like class H.And its not good sounding for Bass speakers..,but it works really well in the mid hi.
I prefer the bass sound with Class H or Class D, This amplifiers In my experience, sounding a stronger and bigger bass.
And of course in this freq range (bass freq. area) do not hear distortion,which are inevitable in H, class G amps. D class in my opinion have other disadvantages, too aggressive play, have a too attenuation of the upper harmonics, where they lose the naturalness. But this another topic... So often we see that active speakers are tweeters (HORNS) powered A/B class amplifier.
Of course in strong systems of the distortion that naturally tolerate.I'll make a few images inside of my factory amps, it's always interesting to see,right?
Apex 900 looks really good!
irvynejay.
yes but you have to change 2sc5200.2Sa1943 to MJL4282/4302 and ic stabilizer for ne5532...
But better ask mile for sure,,, for me i have to stick on what voltage given to the amp and change 5200/1943 to mjl then higher the amperes of the trapo..
Tony.
if you want more power, then build yourself several amps.....why put all your eggs in one basket....
if your one big amp fails in the middle of a disco dance, then that would be a shame...
otoh, the chances of several amps failing all at once is very slim....
i have received several inquiries about modding amps to use higher rails.....and for me, this is one practice i would like to discourage.....
Yes you right irvynejay better ask mile for sure, but apex where are they?
I have an experience with the chine’s amp, same PCB and parts, but the deferent is the no. of power and increasing the voltage.
Sometimes I change the things to make a stable of 2 ohms, most of the chine’s amp can’t handle 2 ohms load. Any way some people can’t handle of these things because lack of experience may be.
Thank u.....
check this schematic
Dear nazridi
1. +/-15V for external use not necessary to connect only connect 18-0-18 AC for protect circuit supply.
2. connect 24 VDC fan
3. amps speaker + o/p connect to 'FROM AMP' side & 'TO OUT' connect direct to speaker + connector. Leave the negative ,it should be connect directly from amps negative.
Dear nazridi
thanks for reply mkubawat.
i didn't understand, can u check the image, is it correct?
