Is anyone around here using this DAC chip?
I'm buying a few this week and i will need some help with the implementation.
what sort of Implementation
I see that people mainly use It as a I2S Input DAC
I am also Interested but I need and spdif receiver part
can you buy few es9023 for me
Talk with the user massimo. He might have some more chips left. I'm buying from him.
I will also need a spdif/toslink reciver. And it will be the first dac ever for me.
See the latest post in the "open source USB-DAC - audio widget" thread. There is a PDF of the AB-1.1 schematic with the es0023.
Alex
thanks!
Is there also a pcb file there? i haven't found it :-(
10 pcs still available......
WM8804 is good & cheap (around 3 EUR)I will also need a spdif/toslink reciver.
The schematic is open source. The pcb layout is proprietary.
Alex
Goddamnit!
I will need some serious help on this one.
but...at least i am one step closer.
that schematic Is usb DAC - Is that what you want
I will try to use it as a reference only. If the pcb file was available the situation would be diffrent.
I would like to buy at least 2 pcbs like http://www.diyaudio.com/forums/digi...ng-new-ess-vout-dac-es9022-5.html#post2447958
he said earlier that if there Is an Interest he can make GB
Yes, pin-to-pin compatible.es9023 is a direct replacement for es9022?
I want 10 pcb's , or 8 at least.
I have contacted him
expect to reply to this thread
I would be keen on a dac board with ess9023 dac chip. it would accept i2s input too? do you guys know the differences (subjectively and/or specs wise) between the 9023 and 9022? Or how it compares to the WM8741 dac chip (ie. twisted pear opus) ?
any idea on pricing for one?
many thanks,
Tuyen
many thanks,
Tuyen
I started updating this pcb to incorporate a 50Mhz XO for the 9022, but due to real life, I'm unable to go any further at the moment.
I only made 5 pcb's originally, and apart from a small mistake on the spdif traffo, they are all working fine, with a nice sound. I'll update when I have a bit more time.
- Digital Source
- ESS ES9023 DAC
