Fountek FR88EX 3" build
Here are some pictures of my latest build. I was going to wait until I had completely finished them, but I am still undecided on which way to go. This is my second speaker build and my first single driver. You can see my first build here :First build: X-LS mini-monitor
Thanks to Bigun for sharing his Martello plans. I am really enjoying the speakers and I would have to say they have exceeded my expectations. I probably have 150 hours on them right now. I am listening to them nearfield on my desk and the soundstage is really good.
I have not glued the backs yet. Waiting to see if I need to add anything. I lined the inside of the speaker with several layers of wool felt. I may need another layer. We will see. Speakers are constructed from 1/2" BB plywood. CNC cut by a local cabinet shop.
And finally the finished pictures. I found some walnut veneer on Craigslist for cheap so I got it. I used the iron on method and some wood softener. It worked pretty good good, but I bid have a few splits.
I have a pair of fr88ex in 2,5l ported tuned to 70Hz. I have tested many options but found that they sound better with the notch. I'm using 15uF, .22mH, 4.7ohm which makes a bit narrower (more Q) notch than that posted above, but it's still centered at 2700Hz.
If you use them as desktop speakers, BSC is not absolutely necessary, but I have had best results with about 2dB BSC.
