Pictures of your diy Pass amplifier
XA 50:4
XA 50:4 It works since Dec. 2010.
  • Transformer 1500W (seondary: 1x44VAC)
  • 48VDC CLC => 8x10mF ->L L->8x10mF
  • Stereo =>32x IRFP250N
  • Total idle current: 7Amp DC
  • Temp at the top: 55°C
  • Cooling: Alu plate 2.5mm Complete: 1 square meter
  • Top and down plate: 12mm
Pre amps:
  • Top: Attenuator
  • 2. Aleph P1.7 incl power supply
  • 3. Pass Xono
  • Bottom: Power supply XONO
  • On the side: AC Supply with 4 double filters
  • Duration of simulation 1 year
  • Construction phase: 1 year
They are not purchased, my friend made them.
Looks like I'm going to have to wind my own.
Your power amp is a work of art :cool:
Tanks Zen
146 Feet but got loads of trubles converting that to meters
evvery time I got past a certain point I have to turn a corner and loose count.
And I am only size 7:D
Joke
right 50 meters shuld do nicely but calculator came up with 0.36 R
Had 2 on the mule cooper came by the kilo so I got 2 kilos and it was 2.5 mm square.
Not a blody clue of how meny henries and they look crap as right pain to bend and wind nicely.
PS tanks for calculator I sure it be handy.
PSS How do you mannage to find this stuff and remember where it is?
Official Court Jester
Joined 2003
:rofl:
that's famous Mighty ZM's Futile Attempts Method :clown:
now you can go nutz ..... old recipe :
"some data for my chokes (presumably 9mH, certainly 0E2 Rdc) :
EI72 package
height of package ~30mm
entire window filled with 1,25 enameled wire
air gap ~ 0,5 mm "
