hi all ,
I am already finished AV400 amp and work fine.....
i alredy bought IRFP240 IRFP9240 mosfets but price is too high.
i had only 3 pairs......
Resently i start av1000 amplifier
i build AV1000 amp.... and test work fine.
i need IRFP240 IRFP9240 power mosfets to complete this amp
min 50 pairs
please help...
i want cheap rate.
where to buy in india?
THANK YOU FRIENDS.
min 50 pairs
please help...
i want cheap rate.
THANK YOU FRIENDS.
hi all ,
min 50 pairs
please help...
i want cheap rate.
THANK YOU FRIENDS.
hello ashokavarthanan congratulations first!!!!!! i am also from India, hyderabad
i am glad that you tried out the av400 amp, which i am now planning to. OK I just want to know how good av400 is in
1.sound output quality,
2.distortion levels, etc.
3.what did you use it for? full range audio or sub-woofer?
4.what speakers (company/ rms watts)did you use at the output?
5.what is the exact price in Rupees you got each of IRFP240 and IRFP924 mosfets?
6.is the Amp's Sound output as loud as a general public address amp?
thanks for reply..........
thank you all.
_______very very excellent... i alredy use stk4231 amp
_______but av400 mosfet amp very very fine.. excellent bass depth ..
_______50-0-50v 6 amp Tr (( recom 10amp or 2*6amp)) . power supply volt output _______70-0-7v
_______10000uf 100v tin type.
_______2 stereo av400 amp
_______3 way tone control(tl074) build in
_______10 band eq.. ex.
_______full range audio system one
_______sub-woofer two for my home theatre...
i used 10"subwoofer 4"mid range 3"tweeter network board.. (per box) for my
stereo sys. sub and mid dainty, tweeter is philips.
my other one big stereo system is 2*12"subwoofer 2*4"mid 2*3"tw per box
amplifier is av1000.
i bought 200rs per pair but price is high ....
yesterday i start new av400 amp to my fr. and cnc machine.
thank you.
SoRrY FoR mistake EngLiSh.
i bought at bangalore 200rs pair thank you.hi
greetings you can get IRF240 IRF9240 FROM KHANDELWAL ELECTRONICS
BHAGIRATH PALACE NEW DELHI HE HAS ALL IRF MOSFETS
THANKING YOU
ANDREW LEBON
thank you.
hi all ,
min 50 pairs
50 pairs ! wow I used 6 pairs in a 1600watt amplifier.
parts mount ... and mosfets and TR 50-0-50 600va per channel.
hi ashokavarthanan,
can u share the pcb layout in pdf format.
thanks.
here is pcb layout by ashokavarthanan.hi ashokavarthanan,
thanks.
hi ashokavarthanan.
thanks for the pcb.
did u edit the pcb?
- AV800 AMP NEED IRFP240 IRFP9240 price india where to buy cheap
