X0.2 Preamp advice & circuit
Want to know which diy preamp design is most similar to the X0.2 and where schematics might be available
Also looking to modify the the input and output coupling caps on an X0.2 and they don't look the same as the X1
In an earlier post Mr. Pass offered this on the X1:
>>There are film input capacitors (1 or 2 uF depending on the rev #) and 220 uF + film bypass on the outputs.
You may replace the caps with the parts of your choice, but of
course you bear the consequences of mistakes.
As the to 220 uF output caps, we are currently favoring the Elna
Silk capacitors, of which there is an inexpensive 220 uF at 16V
available. >>
Values anyone?
Thanks very much!!! Barry
X0.2 board
I don't have its schematic but I own only its control + suplly + audio board.
Very huge PCB which I never seen before !
I bought from my friend in Spain.
Anadigit
Simmilar to X0.2 you say?
available. >>
Values anyone?
Well, you can try this ...
http://choky.diyaudio.rs/downloads/The Pumpkin & Shunty.pdf
and the thread is here ...
http://www.diyaudio.com/forums/pass-labs/119070-pumpkin-preamp-more-boring-making-thread.html
Highly regarded design thx to Zen Mod.
Controller
Semi completed preamp.
66 Steps attenuator.
6 Inputs and 2 Outputs.
30 second muting.
Stereo/Mono
Balance/Single End
Next step I'll change 7-Segment display to VFD Display.
Anadigit
AEON
Hi Anadigit, did you find your axon (note the spelling) caps? although they don't stock the 10 uF size, partsconnexion has 11uF axons for $2.88 US each. AXON True Cap Metallized Polypropylene Capacitors
Tony.
No, I still finding 10uF AEON from US supply. Now I have some problem about 2SK389 from China supplier I think it was remarked from someone whom want to get my bullet :mad:
When I test original 2SK389BL from Borbely Audio I got 12mA but when I change to Chinese 2SK389BL (look like new screened) I got over 30mA !!!
If i have a time enough for DIY I'll cut a circuit of X-buffer to Pumpkin Preamp :)
Anadigit
Semi complete !
These're my semi complete preamp, I used 20uF AEON and 10uF Panasonic.
Goal of this preamp is Unbalance Output because it's hard to select matched resistor and current LED for CCS control. I prgram Atmega MCU only volume and selector control also display shut down function. I can't find hard to obtain 20*1 VFD display as original designed.
Anadigit
VFD display
Now I try to change 7-segment to 20x1 VFD display. it's almost completed :)
I bought this display from OEM factory of NAD S500 cd player display as spare parts.
I have many idea to use them and apply to other function of input/output and volume control.
