Now I know how you placed those big shunts in the dac.
I tend to run the shunts between 250 and 300mA... they sound much better this way.
As heat and size are an issue I did not experiment the shunts in my CDP. You can not place them on top of a dac or decoder or clock as I did with the Spowers.
The big advantage with the shunts is that you can actually "tune" them by choosing the best combination of Vin, Vref and output caps. You can even go further if you choose a special resistor for Vref.
Shunts might be good for tunning the DOS
My player sounds good now, Do i leave it alone too settle or play some more?
alan
LOL. Wrong place to ask that question I think.
Ian, your DAC looks the business!!!
Lee, I know what you're saying about detail, but I am still a complete sucker for the solid, natural fleshed-out tones of the old 1541 players. The treble aint as clean and the bass not as solid and deep as some but it's music, for sure. I found my CD63s left me just a little bit cold. They could impress but not satisfy.
Yeh, I'd normally agree with all of that, but I recently modded a Pink Triangle Ordinal Cd player (2 x tda1547) for someone and that has the same sound character as my TDA1541 player/dac but with much better treble information. It still uses opamps for I/V and output too!
The Pink Triangle does not sound brighter or more clinical, just better.
People would be very suprised by how smooth and analogue my player is, it's pretty close to the TDA1541 in the way it delivers sound but without the draw backs. I'm still waiting to hear a cdp or cdp & dac setup that offers more detail and overall sound quality.
Lee coming over to our house next Wednesday for a refresher session ;-)
Also Lee as you are starting from scratch with this one sack off the std tx and get the larger VA ones in from the start.
Brent
Brent
Yep I can agree about those dac7's. I was floored by the sound of a vrds10 I modded. It also had twin dac7's. You can also bypass the inboard dac IV opamps and make an external one which is what i would do!
Yep, I'm alive just been busy again and to be honest, I'm not enjoying having to actually do some work for a living lol!!!
My CD951 with DOS and few regs was very good, body, extended, detailled. That was that TDA1547. But sorting all these PS pins...
Lol!!! No pain, no gain!!!
Brent
Great stuff, looking forward to it again.
Will bring the
I believe that most dac chips sound incredibly similar in character once all the surrounding circuitry is sorted. My tda setup sounds so alike to the other top players i've heard, but is just lacking that last bit of detail and openness.
Lee.
Will bring the
Lee.
2 tins of bitter shandy won't get you through the front gate mate!!!!!!
Err
Basically any resistor that feeds a 5V to a chip needs removing. At the chip side hole of where the resistor was solder in the out pin of the reg. Tag the gnd down to the ground plane of the pcb (better still run seperate gnd wires back to a star gnd). Run a wire from the main smoothing cap (before the std reg) to the input of the new reg and repeat for all of them. Of course seperate tx and psus is even better for all these regs but that's an whole new world of pain.
Brent
Brent
It's not conductive.
I use it mainly for transport reasons with customers equipment. What it does is stops the strain on the delicate pcb tracks when used around things like big caps and/or regulators
Brent
Thanks, that's great, I'm planning to move some regs and they'll only have one pin soldered in to the pcb. Hotmelt seemed the best option to keep them solid but I wanted to be sure that there was no danger of shorting them through the glue.
Pete
- Digital Source
- Marantz CD63 & CD67 mods list
