marantz cd54 won't play unless it warms up
I have tried finding an answer to this on this board as I know I have seen it discussed in the past. My Marantz cd54 won't read a disc unless it has been powered up for 45 minutes to an hour...I know the 3 large 2200uf caps look bad other than that not sure what could be causing it...
danico..
I don't have a schematic...and this one has a CDM-0....I looked under the transport and all caps look solid...bt i will get a hold of some and swap them out...Albeit, when it does warm up it plays like a charm..
You will be very dissappointed....If you need 45 minutes warmup for it to play
it means there is a break somewhere.Download the CD63 service manual it
should be similar.Try swapping the flexi cable of the laser or check the pcb board for hairline breaks and various cable assemblies.We give too much credit to electrolytic capacitors.:D
Maybe this tread can help you. I know I just read about the same problem.
http://www.diyaudio.com/forums/digital-source/7849-extending-philips-cdm4-life.html
" I repaired a B&O CD5500 version 2 (CDM4) once with the identical lowering of sampling test voltage after a few minutes. Turned out the 33ufd axial cap in the laser supply servo board was on the way out. After replacement the machine has worked flawlessly for the client with an excellent 50mv center of disc laser sample. This has been 5 years now. I've seen many CDM2 with this identical problem."
Revive an old thread to see if you guys can help me out.
First, I'm good at taking things apart and reassembling them. I have no skills in reading schematics.
I have a Marantz CD-54 that would read and play the first 2 tracks of a CD and then stop. I bought a replacement CDM1 assembly from EBay - supposedly NEW.
I have the new CDM1 in and the CD spins but never gets to the Table of Contents (TOC). I do see some difference in the CDM1 board. Notice the GREEN and YELLOW wire specifically. I don't know were these wire should go now.
I see on PIC 3 there should be an ORANGE and YELLOW wire attached to the pin board. However, I don't see a ORANGE wire that was part of the old CDM1 hook up. There is the YELLOW and GREEN wires that I mentioned earlier that I don't know were to hook up. Maybe the are the Orange and YELLOW equivalents?
PIC1 is old CDM1
PIC2 is new CDM1 w/o yellow and green wire attached
PIC 3 is from the Marantz CD-54 Service Manual and where the color coded wires should attach.
What do I have messed up here?
Administrator
Joined 2007
Usually (99% of machines) the platter only spins when focus is found, so the platter spinning means the laser is working at a basic level. Next step would be to connect a scope to the RF signal from the laser and check that the amplitude/quality is as expected.
One of the main problems with all these old Philips players are the electroylitics... and I can see a 33uf axial in your pictures.
Administrator
Joined 2007
Hmmm... that's part of the disc clamp retainer. Unless its physically broken I'd be surprised tbh. The clamp is magnetic (that's 526F in the drawing) and as long as it drops onto the disc and isn't fouling anything then it should be OK. The part arrowed is just the "cage" that holds the clamp when no disc is present and the drawer is open.
If the CD sits on the platter OK and spins true (look edge on at the disc as you rotate it, you can spin it by hand) then there is no problem in that area.
Administrator
Joined 2007
If the laser wasn't working then it wouldn't spin. The laser finds focus first on the stationary disc and only when that is found does it spin... its easier focusing on a stationary object than a spinning one.
The disc should run absolutely (and that means perfectly) true when looking down at the disc edge from above and when looking horizontally at the disc edge from eye level with it. Try a couple of discs... some can have lacquer that spills onto the edge and give misleading results. If its not true then there is a problem with the way the disc sits on the platter, or with the platter/motor assembly.
I should clarify....the disc looks to spin perfectly...its just that little plastic part I mentioned that doesn't look to spin in a perfect circle......how would you like a project? This thing is DOA as of right now. I can bundle it up and send it to you. Send me a PM if you have an interest. I could pay you for your time and any parts.
Administrator
Joined 2007
That sounds OK then... those clamps do sit "randomly" on the disc as they fall into place.
I appreciate your confidence in my abilities :) but I've enough projects (and otherwise) to keep me occupied tbh.
I still suspect your problem has a fair chance of being down to old and dried out electrolytic caps.
