Building kits now. Should be on sale shortly.
Do you need help?
Will be high power bipolar Placid be available at the same time? (High Power Placid, Legato 3.1 bundle)
Patience gwashoppa
Is anybody else making the daily trip to the TP site to see if there are Legato 3's available? It has been quite a long time, I believe my health and well being are being affected. Mental disorder, LLAS. Lack of Legato Acquisition syndrome.
Same symptoms for Trident 3.3V for another project.
This could become serious.
Working on the page right now. They will be available tonight or tomorrow morning.
Very curious when 8ch DAC on ES9018 will be available?)
The non-buffered version simply does not come with the buffers. The BAL/SE output in that case can come straight out of the BAL/SE converter. The circuit has jumpers you install when not using the buffers that close the feedback loop. I am working on the manual right now. It will be clarified in there.
You could add buffers later if you like, but I would actually recommend always using them from the start unless you have some good reason not to.
Is there /will there be/ a schematic of the buffered and non buffered Legato 3.1?
/S
/S
I just ordered... Now all I need is the new placid bp HD and a transformer.
Thanks Russ and Brian for putting all of this stuff together. I can't wait to hear what it sounds like. I have a buffalo 24 module v 1.2 that's been sitting around for two years that I had all but forgotten.
Now, if I could just finish assembling my transport I'll be all set
http://www.diyaudio.com/forums/twisted-pear/175807-buffallo-dual-mono-1-legato.html
We are just waiting for more boards to arrive, so a couple weeks.
Ok folks, I almost have the manual done, but here is the schematic for you to look at in the mean time.
Cheers!
Russ
Russ,
Is that a Zobel network on the output of the buffer? - If so presumably that is to eliminate any possibility of instability when driving a capacitive load?
Martin
- More Vendors...
- Twisted Pear
- Legato 3 - Look ma! No caps!
