Request permission to mr mile, if allowed I will multiply the PCB Apex B class is for people in my own forum Indonesia??
thanks
Use PCB from post #294
Thank you mr .... means I can reproduce the PCB for my forum, in particular?
Yes, pcb design is share to be made by diyers, commercial version have different pcb, and something is add on the circuit for more reability.
Thank you mr mile?
hello sir apex can i use this apex550w in outdoor? pls reply
regards..rompi
Yes, for what aplication?
Nice, I suggest to use some protection...
thanks a lot for reply.For protection i am relying upon onboard fuses.
PCB with corrected track layout, offset is high but OK, no need to place 1N4148 to heatsink this is class B amplifier. Can you post pictures?
sorry mr for the top layer can be displayed?
I suggest to use this speakers projects.
what is the unit measurement of this speaker?i love to build this.
Most PA units will work fine in this speakers projects, and there is some new subs with 18inch woofers.
All horn-reflex subs work clear and louder than other sub plans.
http://www.diyaudio.com/forums/multi-way/174053-diy-pa-speakers-setup-line-aray-3.html
hi sir apex thanks alot of your reply. the application you mean is can i used it in mobile disco to drive woofer tweeter and midrange pls. reply
regards rompi.....
Yes, this isn't Hi-Fi amp.
sir apex thanks alot of your reply much better the b500 than b550? for mobile sound system..
regards rompi
If you have high-qulity PA speakers use B500...
Mr for the size of the top layer does not match that already on display in front?
PCB size is 110x105mm, fit top layer in this size.
- QUASI Amplifier for Beginners
