1000W SMPS Based on IR2110
Hello
I wanted to share our SMPS based on IR2110 and SG3525.
Thanks LuV for PCB design
More pictures and test results will upload very soon, I have to compress pictures
Short circuit is included in SMPS also for protection
Any comments are welcomed
  • smps v2.1 Parts (1).pdf
  • smps v2.1 PCB (1).pdf
how about low noise, and low output impedance in the audio range?
Simply will supply you with high currents, So its very easy to drive 1000W amplifier with this SMPS (heavy use) and maybe 1500W amplifier for music usage. also low loads are not a problem, either
Since 60 mv ripple at output, I think this is a rare thing into this SMPS.
This SMPS came up after several protos, and its ROBUST, and its WORKING!
I'm sorry, but it looks all wrong to me.
First: where's the power incuctor? All SMPS need an inductor for energy storage and halfbridge transformer isn't one, shouldn't be at least.
The MUR460s from switching nod to rails is a waste of diodes and these 18k resitors to the caps midpoint is a waste of resistors and watts.
2mF to form a midpoint is way too much, especialy if you use another series little cap. Keep in mind that the midpoint is self balancing itself because of secondary rectifier.
Also these 4x1mF capacitors don't decouple switching currents, they conduct them, so you really need another capacitor across the rails to close the fast current loops before the mains rectifier.
PCB guides:
The resisitors standing upright the PCB aren't any good here, they are too close to each other's and other components' leads. Have o look at R4 and Q2 gate for example. Put them further away from anything they could touch (they will vibrate with 1000W music with some bass, get close enough to spark and BOOM).
Secondly the gate drive signals are critical for any switching circuits, the upper side gate drive track experiences high dv/dt and they both experience high di/dt, especialy with powerful driver like ir2110. What you have done is laid them very very long and with close proximity to each other, so that both capacitive and inductive interference between them will occur.
mur810 rectifier diodes are on their limit or very close to for 1kW +-50V SMPS.
1- MUR460 is not installed in real SMPS, it was there JUST in case some one used an IGBT without diode.
2- 18K resistors in your mind are needed, but I think they are VERY important to bleed caacitors when you disconnect the mains, better than getting shocked by the lethal charge into the capacitor. so I prefer to keep them even if thats wrong, while its Not.
ALL manufacturers using same thing, they cant be wrong.
3- What power inductor you are talking about exactly? if you mean ETD49, It ok
4- Not sure about witch capacitor you are talking about, the 1UF
5- that 1uf across high rails is there in real application
You sure about that? The only thing I see missing is the inductors in the output filter.
Those 18k resistors are crucial to keep the bridge balanced. The MUR460s are ten times faster than the body diode and still cheap as dirt.
If the midpoint is moved a bit in one way for some reason, one secondary pwm pulse will have greater amplitude than the other. Through the secondary rectifier for the higher pulse will flow higher current, discharging the capacitor with higher voltage across it, bringing the balance back. Same should work for transformer flux, with some help of Rdson.
The speed of mur460s and bodies isn't that important for the simple reason: for a good low leakage inductance, well snubbed transformer no current flow there anyway. never.
OK
Don't know ALL, but I believe MANY use startup resistors with self-powered scheme, so that startup resistors bleed the capacitance without dissipating 2 or 3 watts all the time. Also NO manufacturer allows the customer to touch the guts of the circuit with lethal voltage across. Connected to mains or not.
The one that is missing. The transformer isn't the inductor except for some small leakage inductance, which is minimized. You have to store the energy in magnetic field somewhere.
Where? I'm talking about all of them
Good!
Hope you find my comments some helpful.
Adam
11 turns 11 Turns for primary
8 turns 8 Turns for Secondary for +-50VDC
You will need to use litz wire if you can, or strand 0.2mm wires or 0.3mm wires
in total of 1.5 ~ 1.6mm for all together.
Example, 4x 0.4MM = 1.6MM
use that for primary, and for secondary
Hope this helps
I admire their efforts to achieve a good smps, perhaps the road is still long.
Meanwhile, 4x0.4 = 1.6 (only in mathematics) is not on the wires.
