BURMESTER 006 2 x PCM1704 Philips VAM 1250
CLASSE AUDIO CDP-10 2 x PCM1738 Philips VAE 1250
CLASSE AUDIO CDP-100 2 x PCM1738 PMD200 Philips VAE 1250 Pro
MERIDIAN 507.24 AD1852JRC Philips VAL 1250
MERIDIAN 588 CS4391 VAE 1250 / DSL-710A
NAIM AUDIO CDS 3 2 x PCM1704-K VAM 1250
ORELLE CD100 EVO 2 x AD1862N VAM 1250
QUAD 99 CS4396 VAM 1250
T+A CD1230R 2 x AD1853 VAM 1250
T+A CD1240R 2 x SM5864AP + 2 x PCM63P-K VAM 1250
WADIA 302 2 x PCM1704-K Philips VAE 1250
Also Philips CD player devices with the loader model 1265 (which is in use in CD player models e. g. from Primare, NAD and Thule Audio) are hard to find, because this mentioned Philips loader are not in use by typical audio components from Philips. It was used e. g. in the recorder "CDR-765" (only as player drive unit - the recorder unit is an other) and the IDE drive CDD-3610.
The same is to observe by the CDM12.4 head (in use by the old CDpro/CD-industrial units and therefore often to find in expensive audio cd player models) - by Philips I have find this optical pickup only by their CDI models (CDI = compact disc interactive).
I suspect that even the VAL1250 in Philips devices in that kind is in use and not by typical Philips audio devices (usually with the unit VAE1250) and therefore are difficult to determine.
An additional possibility is the use in Philips audio systems (include FM-tuner, pre- and power amp so as loudspeakers).
Both kinds of devices are not to find in the wide range of online cross reference cd player lists like
http://www.nanocamp.de/cd-liste.htm
or
http://www.stereo.net.au/forums/showthread.php/30925-CD-Players-and-their-DACs
and therefore this wanted information is only find by chance.
or
Follow compact disc recorder models I have found:I could not find any Philips players !
The Marantz CD-7 uses the VAM1252.
Marantz DR6050 und DR4050
Philips CDR570-CDR770-CDR775-CDR930 and CDR950;
by the google keywords "Service Manual" and VAL1250 or VAM1250 you will find the manuals online.
There must be much more models from so called hifi systems, PC stuff and CDRW changers for car- and home hifi.
according this auction
PHILIPS VAM VAL 1250 CD Drive Loader für Wadia 302 NAD S500i Burmester 006 | eBay
this loader is in use by this models:
Vincent CD-S8
Audio Analogue Maestro MK2 (96/24)
Audio Analogue Paganini 96/24
BURMESTER 006
BURMESTER 992 RONDO
CLASSE AUDIO CDP-10
MERIDIAN 507.24
NAD S500i
NAIM AUDIO CDS 3
NAIM AUDIO CDX2
ORELLE CD100 EVO
QUAD 99
Resolution Audio CD55
T+A CD1230R
T+A CD1240R
VINCENT CD-S8
WADIA 302
Vincent CD-S8
BURMESTER 006
BURMESTER 992 RONDO
CLASSE AUDIO CDP-10
MERIDIAN 507.24
NAD S500i
NAIM AUDIO CDS 3
NAIM AUDIO CDX2
ORELLE CD100 EVO
QUAD 99
T+A CD1230R
T+A CD1240R
VINCENT CD-S8
WADIA 302
Here are a supplier of CDM12.4 and VAE1250 head (optical pickup) in an expensive version.
Optical Pick-up Units (OPUs) | Enco Systems
Maybe NOS devices from Philips, made in Japan, no cheap China copies in bad quality.
Are there any experiences?
I am interested in a cd player to use as a transport. I would like the player to have a VAM1250 transport. A unit with a VAM1202 would be ok too.
Why didn't someone just point the OP to Vassili's site????
CD-Player-DAC-Transport List
Cheers George
Just for reference if anyone should stumble on this old thread:
Philips Audio CD Recorder CDR779/00 uses the VAM1250 module as the play-back unit.
(This CD-Recorder isn't included on Vasilli's site.)
I'm repairing one at the moment, so there can be no doubt as it's clearly labeled.
Rgds.
Rgds.
I would ask here for an NOS version "Made in Japan" :
https://encosystems.net/contact/
I'd be interested in how you get on jpk73... I have an Audio Analogue Maestro with an intermittently faulty VAL 1250 9305 023 25001 E143838 drive
which I'm looking to replace. I recently managed to pick up a cheap Philips CDR775 and tried to use the VAM 1250 9305 022 25001 E143838 fitted from that, but when fitted inside the Maestro, it won't read CD's. I've just refitted the donor drive back into the CDR775 and its working fine there... so my search continues...
I successfully tested the replacement mech I got from the seller in Germany: it's an original VAM1250 by Philips, he has it from a (closed) workshop stock, I wired it in and it played fine in my Naim CDS3 (the Naim is said to perform a special test routine and reject the drive unless specs are spot on). Not cheap, but I think worth. He has some more left, so if you want to buy one from him you can contact him here.
- Digital Source
- What players use the VAM1250
