Lm1875 stereo amplifier
LM 1875
when i switch on the circuit it works fine but after few seconds it goes dead ,
when i switch it off and switch on it immediately then also it's dead but i switch on after 5 - 10 seconds then it works finely but again same thing happens
i have attached a thick aluminum plate for heat sink
can the problem be because of slew rate of TL072 ic
(the slew rate is 13V/us ) or whether the circuit starts to oscillating.
:confused:
It is nothing to do with TL072.
Are both channels doing the same?
I should checkout that the supply rails and ground are correctly attached.
LM1875 should take +/-21 Volt, I think.
Another thing that can switch off the amp is output shortcircuit or too heavy load.
Use one 8 Ohm or 10 Ohm power resistor as dummy load.
Checkout what you have connected to output pins.
thanks Juergen Knoop , lineup both channels working but the
cap c4 has developed a bulge and that channel is dead now
before also this problem of cap occured, the voltage at ic TL072 at Vcc is around 9.6v but the other -Vee is fine i have checked the supply voltage +21/-21 both fine .
what was the reason to remove r3 and r17 can u explain to me.
You probably installed C4 backwards, and the reverse voltage caused it to fail. It is also possible that it was just a bad component in the first place.
p.s. why are you double posting to here and to the solid state forum? Don't do that.
