Sample 4 Channel APEX B500 and use bridge mode future.
can u post high quality pictures of this amp.
teslar
good transformer how many kilogram?
Hi engel dela pena.
50 Kilogram up
Regard.
Hi nazirdigi.
High quality pictures of this amp.
Regards.
pls help.
here is my b500.
first powering up with fuses 53vdc,0,53vdc amp works fine.
i used 2sd669a instead mje340. it works fine .
after one hour i change mje350 to b649a. in near d669a 100ohm resistor burned and fuses blown.
after i remove d669 and 649 with mje340,350 but same problem fuses blown.
can any body help to solve this problem.
here is my b500.
this is the photo of the parts.
Hi nazirdigi.
I think pre driver & Out put problem.
1.Teak out all power transister out put.
2.Replace all berned part.
3.Check DC power at attachment.
And surely all power transister out put no short to ground and heatshink.
Regards.
Hi apexaudio
I plan to make 500 PA as Subwoofer car amplifiers, how do you think? thank you
Class H or class D is better for car amplifiers.
nazirdi
please double check this traces
i try to figure but i can only assume maybe i was wrong.
hi engel dela pen
i removed all power trans and checked 2 trans burned.
i checked the traces its fine.
may be b649 is fake i think.
thank's Mr. Miles and Mr.Coolet
hey man is this h900 or b500? wrong thread.
This is recomended protect.
Sorry mr mile ... for the size of Protec pcb layout?
thanks
hi apex sir .
i bought a new transformer for b500. after rectifies it gives 80.0.80vdc .can i use 2.2k resistor for r24,25 or i have to increase the value of resistors? any other changes.
2k2/2W is OK for R24,25
thanks
80x75mm
- 500W PA amplifier with Limiter
