Correct.
This scheme needs positive and negative power rails.
Look at the top left corner of the PCB design, there are the 3 power connections (GND, +Vcc & -Vcc)
i saw in the website only two connection given. why is that. i'll post the image.
in the parts list there mensioned 9v dc 300ma trafo.
if i put 12v ac dual supply 1A trafo is it ok?
PSU for preamps and active x-overs, with different zener output voltage can be +/-12V, +/-18V...
hello apex sir
I have 12v ac 1A dual supply trafo. so for the preamp what are the changes in your power supply i have to?
can u post the top and bottom layout in pdf.
links service manual and schematics
try here Bro
Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
hope it helps
greetings...
sir miles i'd like to ask if you have a schema for linking amplifiers...
thanks,
ees
try here Bro
hope it helps
The transformer, is in effect, simple (no center tap), but the source is with half-wave rectified and if you enlarge the image to 400% you will see 3 out cord
thank you Mile I build this one and its very good for sub I test it with dual TDA stereo as I build before the result was great and sub is shaking the room, here the PCB with PSU I used for it.PCB size: 60x50mm
top:
button:
power supply from 35v:
but I still have question about two things what is AUTO used for?
and speaker input I didn't use it just use the line in again when I can use them?
Hello Mile, First let me tell you that your contributions to the DIY community is priceless, Thanks for all the stuff, I just need to know how I can bypass the tone control part of ML3, is there a way to turn it off, thanks in advance.
IC1 is preamp, IC2 is EQ. Use output from IC1B out if you don't want tone controls.
Thanks Mile, Also can you post the PCB layout for the Preamp you describe on your Class A PSU thread it looks brilliantIC1 is preamp, IC2 is EQ. Use output from IC1B out if you don't want tone controls.
http://www.diyaudio.com/forums/power-supplies/164365-class-preamp-psu.html#post2141076
ASK TONE CONTROLL MR APEX
I've assemble tone with potensio 2x50K controll apex.
I heard the high voice is not good but if in a low voice I feel pretty catchy.
I question whether the components that I use have to be replaced?
help me Mr. APEX.
greeting
The following picture
help me Mr. APEX.
greeting
help me Mr. APEX.
greeting
Use 1nF instead 3.3nF.
Balanced Input
Do you have the copper side of this Balanced Input Sir???
In PDF..
You can use this circuit with GND lift switch,
In PDF..
ML3 Schematic
hi sir Apex how to add echo volume with your ML3..
regards,
nix
I do not get the echo effect for vocal sound. always based PT2399.
does anyone else?
this for microphone with echo volume if he have it possible additional parts or i.c. im waiting for the response of sir apex.
thanks in advance.
regards,
nix
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
