DIY progress report
I have decided to build a new speaker. I'm going to try my hand at the Lowther TP-1 Isis using DX4 drivers. I'm curious what amplifier would NP recommend to power these? I'm looking for a range of ideas I guess. I'd love a gen-u-ine (with a Texas accent) INT-30A, and might be able to pull that off, but perhaps there is a better choice? a more realistic choice?
I put here my own experience about matching mosfets.
The method :
On a thermostated table home made, regulated at 35°C +/-0.3°C :
I measure the Vgs when Gate and drain are connected, and Ids injected by a regulated source of current.
The Ids are 100ma and 200ma
Two full batches of Irfp240 and Irfp9240 (2x1000 mosfets).
Here the results for the two batches :
Vgs of the Irfp240 and 9240
Magenta : Batch 1, 200ma / Dark Blue : Batch 1 100 ma
Cyan : Batch 2, 200ma / Yellow : Batch 2, 100ma
You can see that the batches of 240 are better than the 9240 ones.
These batches permit to have a good sextet matching (1mv for 240 and 2mv for 9240).
diyAudio Editor
Joined 2001
Check out the last newsletter with the article about Burning Amp. It discusses the amps Papa used and a filter to make it work..
Joined 2006
Hm, I see the F2J mentioned and a network to integrate it with a Seas driver, but perhaps I missed something? Thanks for that though, it was a great read, even a second time :)
Luvdunhill -
I use a F2J clone,
with a lowther PM5A, a 10R-10uf across the terminal sounds good to me. (running OB)
next choice was 10R across the terminals. I left out the 3x47R resistors in F2J.
I wonder what Papa or Jon ver Halen use in OB with PM5 or 6A.
I have not experimented around too much. it sounds really laid back, with a sweet mid and really nice top end.
diyAudio Editor
Joined 2001
Sorry, you're right, the info was for the Seas driver. Still, clearly the F-2J is a contender!
Papa has a lot going on at the moment so can't post much, but maybe later..
