The only practical reason I can think of is because we are using the jitter eliminator (ASRC) feature and they are not.
McIntosh does the same thing. Only they use a PLL.
I on the other hand much prefer to let the ASRC work.
I think I read that the Weiss DAC202 uses some kind of external PLL for clocking. I guess everyone has their own way of doing it. I just thought using any ASRC always introduces jitter. Though ESS may be better than most.
Yes, the input is fully asynchronous. Input may have Jitter up to 50ns, fully random.Is ASRC embedded in the Sabre chip?
I've listened to the McIntosh: it's good, but IMO not as good as the BII (as in not as good as my setup). I think they also disabled the Sabres' filtering, as the McIntosh clipped on a few tracks. And it's a bit more expensive.
Hahahaha "...a bit more expensive" ...just a tiny bit
It does eliminate jitter in that timeframe. But the buffer is limited in size, so that limits the amount of jitter that can be removed. 50ns isn't that little though: it's 50000ps, while around 100ps is usually the jitter from a CD players clock. In other words: you'd have to find a pretty poor implementation to really be overrun by jitter.The ASRC still acts like a filter though. Never completely eliminating jitter.
I don't think it matters whether you use one clock or two in an ASRC. There is a belief that using even multiples of the original clock is beneficial. But in an ASRC the input clock and output clock are unrelated and the ASRC algorithm just calculates the new samples closest to the new clock rate.
Where it matters is in deriving the master clock frequencies, and this is typically during clock recovery. You get less jitter with a simple division than through a series of multiplication/division to get at the clock frequency
For our Buf II the master clock is dictated, not derived (which I know you know) so really design needs to center around the master clock. But say in the case of SRC4192 it can be very critical to use master frequencies. And in a situation where you are using a chip like that two clocks would be ideal. But we are talking about two totally different apps.
In any case we designed it the way we have for a good reasons, and I am quite happy with the choice. Adding another clock in our configuration would only serve to increase the cost with no gain whatsoever. Nobody wins.
Cheers!
Russ
True, the common US spelling for a curved backsword is 'saber'. However, the Buffalo hockey team was named at the whim of it's founder, and the ESS chip about which we are supposed to be chatting is a product of the Commonwealth.
...nations divided by a common language...
...But say in the case of SRC4192 it can be very critical to use master frequencies. And in a situation where you are using a chip like that two clocks would be ideal. But we are talking about two totally different apps.
Cheers!
Russ
Hi Russ,
Yes it would be ideal to use two clocks in the src4192 if you wish to support all the 44.1 and 48K families. But if you just want to upsample to a higher sample frequency then it seems from the theory that upsampling 44.1K to 176.4 (even multiple) would not get you closer or more accurate samples than upsampling to 192K (not an even multiple).
- More Vendors...
- Twisted Pear
- Buffalo II
