Studio Reference Amplifier
why is two out in this pcb and there is two resistor in one place?
Hello Alex MM,
I'm wondering if you can post the following PCB foil pattern in mirrored or flip as I'm going to use it for Laser toner transfer method. If possible in PDF format and actual print size please.
Thank you so much!
Blueice23
  • AMPL SR 200 V2.PCB BW.pdf
  • SR 200 V2 BW.pdf
PSU for preamps. I suggest this +/-15V regulated psu instead 7815/7915, 317/337. This serial regulator can give more current than shunt regulated psu (1A max).
