Cascoding the folded cascode
It's been discussed, but I haven't seen it done so I had to try it. In spite of the messy appearance it's stable, low noise and measures well. Measured with RMAA THD is lower compared to the standard arrangement and mostly it's the 2nd harmonic that's reduced. I like the sound of it and think it's an improvement. It makes the sound cleaner and a little bit leaner.
Are j1 & 9 required?
Not required but wanted. I've tried all four input stage concepts - standard, CFP, cascoded and CFP+cascode - and this it what I prefer.
WuYit, yes it's probably esthetically displeasing but I like it. The standard common base VAS sounds a bit rough and muddy. The AD797-like arrangement and this sound better to my ears. I find it has about the same effect as cascoding the VAS in a LIN-type of amp.
Zen Mod, I can try it with a zener instead of the LED, but I't will be hard to tell if it's to the better. The amp adds very little to the sound (when I evaluate amps I usually add them to the signal path). What voltage would be appropriate?
some curious choices there
cfp around high current, low noise input jfet, setting the ~10mA Idss jfet Id at 1.5 mA, adding ~2-3x degeneration re the naked fet's 1/gm - both seem to say you actually don't trust the linearity/square law cancellation of the input jfet's themselves
the diff pair's "cascode" jfets add greater input Vgd 1/gm modulation than the drain R would without the folded cascode - I usually expect a added cascode to reduce the Vswing on the cascoded Q - leaving them out entirely would be better by that criteria
having used the cfp front end you don't use it where it would reduce distortion the most - in a Class A biased output stage
I would move the cfp to the cascoding jfets where the gm boost makes the cascode actually work to reduce input Vds change with common mode signal
and I would use cfp for the output - when used in Class A
and +/-12 V isn't enough for dynamic headroom and linearizing Vbias - I wouldn't want output device Vcb to go below 5 V - as long as it's a descrete circuit why not at least +/-24 V supplies? - with those jfet ccs on the output diamond buffer you need the extra bias V beyond usable output Vswing
at +/-12 Vsupply you could more easily just use an op amp
also I hate selecting parts so I would never use jfet ccs when a "ring of two" bjt feedback ccs just works, on less voltage, with greater output Z, the 1st time with the calculated values - no trimming
Nelson,
no, it is theoretically displeasing. The role of J1/J9 is exactly the same as that of T5/T2. Why devices with opposite characteristics? One of them is not suitable. Consequently, why don`t you want to cascode the input stage cascode as well?
There´s nothing that would make the standard common base VAS rough and muddy (when the voltage gain is kept at a reasonable level).
I've tried - standard, CFP, cascoded and CFP+cascode - and this it what I prefer.
I think this is great - it's DIY afterall, and instead of being lazy like me and some others around here, you have built something and tested it. Good for you!
I'd be interested to hear your thoughts on the relative differences between 'standard' and 'cfp' etc. not just which one you think is best.
As you clearly see I have no deeper knowledge and I appreciate your opinions.
Would it make more sense to use BJTs as cascode devices?
If this is all wrong, why does it have lower distortion both in real life and in sim?
I was aiming for constant power in both input stage and VAS like in this amp Memory Distortion Philosophies , only using a common base VAS because it's what I have at hand. If one believes in the "memory distortion philosophies", does it matter if the VAS is common base or common emitter?
These are my findings regarding input stages. Differences are subtle and subjective. It's not easy to describe differences in sound, and I guess we use different terms. The conditions are not optimal since I use lower voltage and current than most of you, but I can't hear any major differences between low and very low voltage, and between medium and low current.
BJT (BC550, SC2240, SC2362) vs JFET (SK170) - BJT: metallic, "solid state", clean, airy, large sound stage. JFET: rough, dirty, down-to-earth, more accurate sound stage
CFP JFET/BJT: cleaner than just JFET, darker sound, still much of the JFET charachter
Cascode JFET/JFET: cleaner than JFET, bright/lean sound, less JFET character
CFP+Cascode JFET/BJT/JFET: more neutral and natural, cleaner, even less JFET character
CFP BJT/BJT: warm, full and enjoyable but on the dark side of neutral
Cascode BJT/JFET: again a bit bright, clean and better than just the BJT but not as enjoyable as CFP
Nelson,
Yes. It would give you a pure transconductance / transimpedance compound, appropriate devices amplifying solely current respectively voltage.
The voltage gain of the second stage is too high to my taste. Although this is a nice topology, two voltage amplifiers may be considered unnecessary in a (headphone) amp.
Independently from the "memory distortion philosophy", the common base amplifier is far superior for voltage amplification.
I incresed the voltage over the input transistors with no sonic difference at all, and it measures just the same.
Well, I guess you folks are right regarding cascoding the VAS or folded cascode. After some more listening I find the cascoded VAS to be anti-aggressive. At first I found it an improvement with less sibilance/solid-state-sound, and bad MP3-files sounding smoother. Now I think this is a coloration. I think it could be the same in common emitter VAS as well (I've done some experiments with my old Onkyo amps).
I think the perfect common base VAS is the AD797 type. It's simply more transparent and neutral than the standard one and the cascoded one. As for input stage I stand for my findings above.
