Restek Fantasy amp cap upgrade + opamps and Bursons!
Interesting ideas coming out I see. I had no idea anyone disliked the Alps Blue pot. I use one in my preamp and I'd often wondered if there were gains to be had from upgrading - but I only see very expensive options.
Any pot recommendations from Mr HornTube? And don't say Moroccan Black or White Widow ;)
I made extensive listening tests with friends regarding the pot issue. It came out that (the cheap ones aside - too high tolerance etc.) Alps is the worst! The black Alps is better but not very much, Noble is even better. Panasonic is the best non-ladder attentuator I know - I think Audio Note UK using it also. But here is my tip: Buy the cheap ladder att. at eBay - from HongKong or China. They solder the 0.5W Dale resistors on it. Quiet good. The sound is VERY different in comparison to a normal pot. It excels in stage depth, detail & speed. But I would not recommend it for thin or analytical sounding amps cos it is surprisingly revealing. One must be careful cos the difference between Alps blue & ladder att. is like listening to a different amp! So Panasonic is a safe bet and will not hurt anyone. The blue Alps is really killing space & detail & speed - if you like to sleep in front of your stereo - first choice!
Fascinating info, thanks. I've never compared pots really, except for when I changed out a linear Vishay one and a cheap log carbon one for the Alps - their channel balance was too poor and the Alps is first-rate in this regard. I've often wondered if the stepped attenuators improve things much. It looks like I'm going to have to try. Revealing is fine with me, I have a great preamp and first-rate cd player.
Sorry to thread-jack Ian, but maybe this info is interesting to you too. Trouble is finding a motorised alternative, there aren't many.
OT: preamp
I'm using cheap OBs but in my sig there's a link to much better ones I'm still putting together. The preamp is just a simple buffer designed by Pedja Rogic, using S-Power regulators, Kiwame resistors, the Alps Blue pot, CMC silver/copper sockets and Mundorf foil wiring. PSU decoupling is Ruby ZA. Naked caps and 80VA toroid for the fun of it.
Cheers Ian :)
have the same Restek as you do and pretty happy with it, although it has one trivial problem - i could distinguish and hear some music even when the volume control put to silence.
Do you have the same issue and could it be somehow fix, how do you think?
Hi!
I have exactly the same problem. Also, at very low volume, there will be a balance problem. This is all due to the Blue Alps volume control pot.
At some point, I will look into changing it but for the moment, I use the remote all the time so options are limited.
I can't tell you how much better a change to all the caps made. Much tigher and much more dynamic. The std preamp sections is average to be fair and the change to discrete opamps and rework again made a large difference.
If you're brave enough, there is plenty to be gained from an already very good amp :)
thanks for info, now feel a relief about this balance issue :)
I'm thinking now about changing all the caps to Nichicon KZ or FG and the big 10000uf ones to smth. Not sure is there any point to buy expensive Mundorf or BC 114/ 154 series or Kendeil...recently have found Rubycons on ebay, how do you think, does it worth to try them? Also regarding the rest of caps, maybe it's better to find some replacement with OSCONs or Panasonic FC?
Already have done the following mods:
-replaced inlet with Furutech
-mains cable to Belden 19364
-all the original wires on pbc to silver 1.00mm
-speaker binding pots to CMC
-replaced oxidized speaker cable (pbc->speaker terminals) to Kimber 4TC (have 8TC from amp till speakers)
Now it's time for caps and opams :)
www.hifisonix.com
Joined 2003
I am surprised that you believe that with the Alps pot set to min volume. I use a 10k Alps blue velvet (RK27) on my X-Ultra Mini pre-amp, and do absolutely not have this problem. Are we talking about the same pot here? If yes, then this might be a signal switching or layout issue, rather than the pot. Intersted to hear your comments.
I couldn't get the bursons to work in the power stage but I didn't scope it to see if they were driving into oscillation etc. Mine are LME49710HA in the power stage. All the caps in the power stage are panasonic FM (I think) and I cant recommend doubleing the PSU caps to 2 x 10,000uf per rail enough. For me, there is only one cap for this job "F&T" who also made the Mundorf SI's for them (so I'm lead to beleive).
As yet, I've not replaced any internal cabling bit now you've got me thinking. especially as I have a couple of 2.5m lenghts of 4tc kicking about!!! Phono sockets and speaker posts have been on the cards for a while too!
Do you have any pics of your work?
Hi Ian!
You're unlucky with that pot, as the Alps Blue is sold on its excellent channel balance. Mine is superb at low volume.
To be honest, I've not looked any further into it. It could well be the external gain but I'd assumed the pot would be the weakest link. I could swap the balance over on the pot to see if I have more gain in one channel than the other and the problem swaps to the other channel. As I'm definatley not aware of this issue at listening volume, i'd still guess at the pot. Also, on the basis that the pot should effectivly drive the input to gnd at 0 volume regardless I still suspect the pot.
So in summary..........I suspect the pot :D (too many suspects the pot in there!!)
Edit - its a few years old now and crackles a little so it needs replacing anyway. I'd like to play with a lightspeed att. Driven off the original pot but thats just a passing thought at the mo........
Nichicon sounds warm and lower-mid oriented - but not very speedy and lacks a little bit of the detail. The BC's are rather analytical with a little plastic taste, I would recommend EPCOS - the best of the large cap fraction - technically & soundwise. Elna is very good, better than BlackGate IMO. Oscons are only good for digital circuits - never ever use them otherwise. FC's are great, rather warm but not too much - second choice after Elna's highend caps.
Hi Ian,
I did have somewhere... :) probably need some time to find or simply take few pictures of the amp as it's now.
HornTube
thanks for advice :)
do you mean Elna Silmic II or Cerafine is good as well?
Btw, forgot one important upgrade to amp's appearance - Titanium bolts on the front chrome plate. Still waiting for them but once receive could post some pics as well :)
Silmic II, Cerafine, Stargate & Tonerex - they all sound great. Espicially the Silmic & Silmic II are very natural and faultless.
The Panasonics are also very natural sounding, maybe a tad worse than ELNA.
Rubycon ZL, ZLH, ZLA & BlackGates: Icy, cold, screaming HiFi, emotionless, static, destruction of the rhythmical flow, poser, here here I'm a very expansive cap - do you hear me - screeeeeeeaaaam, unpleasant, nervy, bodiless, there can't be too much highs. I have a bag full of this crap...:crackup: - the caps for the beginners not for the connoisseur.
