Got unknown tube preamp board, need help!
Hi, long story short, I found a few empty boards in my stuff and wanted to make use of them. I was quite happy to discover what I believe to be tube preamp boards since I was planning on building one eventually. The trouble is, I have no clue how to populate the board. There is room for way too many components when I compare the board with popular tube preamp schematics.
I know these boards came from a company called caztech, and that the board was part of the spa-2 preamp, but little information is available on the web apart from that.
I could only guess some of the components, I am not an electronics expert but I know how to use a soldering iron. So, if anybody could help me find out what values I should use for the components , or for that matter which tubes fit that layout, it would prove to be very helpful to say the least.
By the way, hi, my name is John, I'm a math teacher who likes to modify and build audio equipment as a hobby.
I draw a schematic by hand; it is definitely a phono stage.
R6, R7, R9, C6 and C7 are the components for the RIAA equalizing.
Two cascaded gain stages with a passive RIAA network in between.
There is a local feedback network around the input tube (C3 and R2).
V1 is the input tube for left and right; V2 the output tube for left and right.
Let me know if you need a well drawn schematic.
I will see what tubes might have been used (pin 4 is 6,3 volt DC I guess; pin 5 is ground).
Based on E88CC is should not be very difficult to calculate the values of the passive components.
A phono stage! That would explain a lot.... I am quite pleased with that to be honest, but I have, once again, some questions.
Before building it I'd like to know if it would be a good idea to use it instead of the quad 33 from the turntable to a upgraded quad 405.
@ pieter: Yes! Please I would very much like it if you had any sort of schematic, even badly drawn on the corner of a napkin. It would save me quite some time searching around and I could go get the missing parts tommorow.
I'll search around for other boards to see if I can find the other parts of the preamp, but in the meantime, in case I don't have it, what power supply would best fit my needs for thr moment, assuming e88cc tubes?
Thanks again in advance.
John,
Here is the schematic for one channel.
I would suggest a B+ of 200V; this must be a very good quality power supply.
When you take E88CC's, which are a good choice for a phono stage, good operating points are with 15k plate resistors (R5 and R11) and 390 ohm for cathode resistors (R2 and R8).
Maybe it's nice to invite some guys here to suggest the values for the other resistors and capacitors.
All coupling capacitors are parallelled pairs and I would suggest to use just one for each spot.
Pieter
Just for safety I guess; many designers seem to do this.
So far I see there is not that much gain in this preamp.
For grid stoppers I should not go over 100 ohms for noise reasons.
I would start omitting the local feedback around V1, and maybe bypassing the cathode resistors to "gain" some extra gain, but maybe there was a linestage further down.
There was a linestage indeed. I will also build one later on, as well as a relay controlled input selector for the complete preamp. I still wonder if I'll find the linestage board or not... it should be in there somewhere...
I'll know more this afternoon anyway, I'll try to figure some of the other values as well.
Thanks, I'll keep posting my findings and build in the meantime.
ECC88 usually has its pin 9 grounded, especially since this looks like a two channel board which could benefit from channel separation.
If pin 5 is indeed DC heater ground, it's odd that pin 9 isn't connected to it, or better yet heater pins reversed with pin 9 grounded, which would make for easier PCB routing (this assumes point K ends up conencted to ground instead).
Administrator
Joined 2004
I searched around the crap pile and I found a 120v to 6.3v transfo and a 240v to 120v. While I wait for the tubes to arrive I will work on a power supply.
What is C3? Can I simply leave it empty?
I don't use a cap in that position in my designs, and do use very high transconductance types like the D3A in the front end of my designs. Arguably it is in parallel with the miller capacitance of the input stage and raises the input capacitance the cartridge will see. It may be necessary for stability depending on pcb layout. I certainly would not go over 10pF or so in a passively equalized design, and my inclination would be to leave it out.
FWIW I would also leave out the input capacitor (jumper it) and install a single 47K resistor as cartridge load and dc path for the grid of the input tube. The input current should be small enough to be a non-issue with most cartridges out there. (Again I don't use an input cap in any of my phono stage designs, and have built a lot of them over the years.)
Hah! Found the main board today, it does have a psu and a line stage on it. The phono stage fits perfectly on it so I'm happy, and it does answer the question as to what goes where for the heater section. It was designed for a toroidal transformer which I can't seem to find but I don't have the original tubes anyway so I'll use what I have for the psu. Weird thing, I seen to have found a second one of each of the boards, I can now make one mistake and still have a spare, ha!
I'll post the schematic and a pic tommorow and I'm afraid I'll ask for help again.
