PCB drilling with a dremel
I have ordered tungsten PCB drill bits from Farnell in the UK. 0.5, 0.8 and 1mm are the most commonly useful. The tungsten bits have a shank that fits the standard Dremel collet.
I don't have a Dremel, I used to use one at work. I have an imported 'KINZO' tool here at home, but I don't have a drill press for it. I was pleased to discover that I could use the massive (comparatively) bench-top machine shop drill press I do have. It's best with HSS bits, but I've also learned to use it without breaking the tungsten bits, by moving in a slow and deliberate manner.
An easy way to break a tungsten bit is to start to move the board before you have fully withdrawn the bit from the hole. This is quite easy to do if you get into a rhythm and are trying to work quickly.
If you have a lot of holes in a row you can set up a 'fence', an immovable straight-edge that you can slide the board up and down against, then you only have to worry about the positioning in one dimension. I have a vice that works for this, the drill-press table has slots for securing this with bolts and wingnuts. I butt-up a piece of thin wood against this with the board on top so I have something for the drill tip to enter before it strikes the table.
w
Disabled Account
Joined 2007
IMO, the Dremel needs a chuck - best accessory to buy for it. It will hold the smallest bits.
I use mine hand held and use HSS bits. Learn to sharpen them with the side of the tiny cutting disks for the Dremel. You'll get thousands of holes from a single $2 bit.
Etch and tin the board before drilling. The etched out holes will guide the bit.
I think the smallest I use is 1/64". 3/64" and 1/16" are my next 2 sizes.
0.033,0.040, 0.052, 0.125
ditto on the tungsten bits. I found that using them on the Grizzly Mill saved me a lot of money. But I now buy a bunch of HSS bits in the sizes I use and just pitch them when they get tired. Dremel and Ryobi have a little press which works nicely. I put the board on a square chunk of balsa and use a bright light to illuminate the work surface.
I do have a CNC machine, but haven't gotten up the nerve to use it, relying instead on my board shop out in Colorado for protos.
Well worth the effort to try the CNC, I wish I had one. I use UV resist board, the uncoated board is 30% cheaper. I made some big boards on the CNC mill at work, 15*24in, 32*9in. I imported the Gerbers into Eagle using a tool from a guy called Falk Stricker, then created the isolation toolpath with PCBGcode. I had to manually tweak the text files to get all the features on the same layer, but it was all possible with free software, even doublesided. Marvellous. They gave me a £5 book voucher for a Christmas bonus. F*cking marvellous.
32" PCB
w
I used to use a maxicraft PCB drill with its stand and found that it works ok. I have used a dremel and the stand with it which seems slightly better.
Carbide drill bits snap quite often when manually drilling especially the ones less than 0.6mm. HSS drill bits wear out in seconds, I found only one board could be done before the drill bit was completely worn.
Luckily I got given a Bungard CCD/2 CNC without having to exchange any body parts or even cash! :)
I always use the CNC to drill the holes first and then use wet etching for the tracks. It gives a much better result and is more economical.
My experience with tungsten carbide bits for PCB drilling is that they don't like any runout in the drill or chuck. A "precision drill" is likely ideal, but expensive. I have gotten away with a lot of slop (relatively a lot) by putting the shank of the PCB drill (which is typically 0.125" here in the USA) inside a bit of "spaghetti" tubing or heatshrink, then chucking that. This provides a degree of flex that the carbide itself does not. It won't keep the drill from shattering if too much down pressure is applied, but it does extend the life.
Myself, I have given up on the possibility of drilling my own PCBs. The only way I could see doing it is with either a mechanical downfeed of some sort (at the right rate) or else a CNC rig. I'd love to go with a CNC rig. These days they are not that pricey, but I'm unclear on how you can get the XY points into the code unless you do the layout with Gerber or "G code" in the first place?? Maybe someone can comment on that... but as the poster up a few said, there is software that can be set up to do precisely this.
Also I've seen some CNCs set up to actually cut the PCB and not etch it at all! :)
I'm skeptical on the Dremel, but maybe there are some models that do a good job in the stand... John I'm impressed and amazed that you have drilled holes hand held, even with HSS bits... not a job I want to do (having tried and experimented with that!).
_-_-bear
I've been (freehand)drilling homemade PCBs with a dremel for years and I have yet to encounter any problems. From my experiences, bits usually break because of poor technique (pressing too hard) and/or improper "drilling backstop".
When drilling, let the speed do the work, put as little pressure as possible on the bit; this may take longer but will greatly prolong the life of the bit.
Also, do not use plywood or scrap wood as a drilling backstop, the change in density (after you've drilled through the PCB) likes to snap the bit; I recommend using a piece of MDF as a backstop.
I started out using a dremel free-hand with HSS bits, but for some of the smaller holes I needed it just wasn't good enough.
I now use a dremel with a drill-press adapter and carbide bits. I can get micro carbide bit assortments at my local Harbor Freight for dirt cheap. I rarely ever break a bit, but when I do it's usually from bumping it with the edge of the board or dropping the bit on the ground.
I've "caught up" with john lately .. :D
In december :
power boards - about 155 holes X 12 =1860 holes
power supplies - 70 X6 = 420
AX/BX - 108 X 16 = 1728
Roughly 2-300 holes for my various crossovers/little amps/softstarts.
4300 holes drilled with a 25$ black and decker AC drill , using the thumb of one hand as the "guide" and my other arm as the "press". Went through 3 #70 wire bits for all 4300 drillings on a plywood sheet as backing. Over 1400 holes per drill bit.
Some holes were drilled out to 1/16" or even 1/8" for larger components (fastons/large diodes).
I wish I could have a dremel , but still it only took 3-4 hours of straight drilling for all those.(with breaks) :eek:
15 minutes and 200 holes I get another 200w "blaster" (below) :D
Next round , heck with this .... let someone else do it. I use software that exports gerber/excellon , even milling data (sprint layout).
OS
If you say so...
just some of what I haven't thrown out yet. Not included is all that I did throw out, can't find or is actually in use in various projects here, there and everywhere.
Hat's off to you for using a drill. Not how I'd want to do it.
I have my "donation pile" as well. I gave some to keentoken , others are being traded for parts and speaker components ... another 3-4000 holes :eek: . Very strong hands and arms doing it with the drill .. ouch !!
PS , don't throw out them wonderful parts (caps) , I even save the solder blobs I "rap" off the used boards in a pill bottle for future tinning.
OS
Oh, a word of warning...
One day at work I was doing some drilling. Despite some huffing and puffing a scrap of GRP swarf still clung to the drill bit. I incautiously waved my finger at it to dislodge it, the tip of the (extremely sharp tungsten) bit contacted my fingernail and dragged my finger onto the drill, emerging from the pad. I can still feel it drilling through my finger in my imagination. Shudder.
I won't do that again.
w
I bought 20 Tungsten Carbide bits from Harbor Frieght for $5. A great deal. I freehand with a dremel flexcord and use the larger bits ~0.7mm. No broken bits yet.
About tinning - I started tinning and found no difference in "solderability". If I laquer my boards after stuffing, if there an advantange to tinning?
If you use SN/CU to tin it - more current. PB/SN just retards oxidation of the copper - very little extra current capacity ,but lower temp. I use mix of both (PB/SN/CU).
BTW , my "1400 holes per bit" were the harbor freight ones. :)
OS
I settled on these with Great Results
Thanks to all for comments and techniques. I am ready to rock and ROLL:hypno2:
The drill is small light weight and just does the job without the slightest strain.:D
Less than 10 bucks on SALE Total
