Bybee Quantum Purifier Measurement and Analysis
You have option to build a boat from zinc bolts and copper panels or copper bolts and zinc panels to leave a deserted island that's sinking in the ocean...can't use just one or the other.
Which do you choose and why?
I would question the situation, how would I be presented with such two options.
Would I have both copper and zinc bolts and panels lying in two piles before me? If so I would take the copper bolts from one of the pile and copper panels from the other.
Would a guy come in a helicopter to deliver them in a box? If so I'll blind him with a handful of bolts then hit him with the panel and jack his copter.
no guessing allowed
You just have to accept the situation as not enough of either material to construct a complete boat... kinda like the faith based principles espounded (or not, eh?) as proof re: "quantum purification...
hint: cathodic rate limiting
Beeh, where's the challenge in that.
The proper way is to have all the rights bolts and pieces.
Then, just before you depart for the deep blue, you're in the mood for an inspirational bowl movement.
And when you flushed the turdies, you leave a thru-hull valve open, just in time before the temperature drops below zero.
Oh, i forgot, space walkers don't have sub-surface stinkers in their shuttles.
Clap your hands and sing along :
I'm an idiot.
I'm a legal idiot.
I'm an astronaut in the John's !
Explosives Sink Ecolution, Innovative Sailing Yacht Owned by Dr. Wubbo Ockels : Old Salt Blog – a virtual port of call for all those who love the sea
:clown:
...theories become axioms then laws then Laws when, after innumerable carefully controlled attempts there is no credible observation that contravenes them. It also helps to achieve the capitalization when they fit into a larger framework that is simple and beautiful keeping Occam neatly shaved. If the Laws of Thermodynamics don't fit the bill, perhaps we should sacrifice a few virgins and seek guidance!
Main news would seem to be that Jack Bybee has discovered how to market fancifully wrapped resistors at a markup of 7418% over the garden-variety version of the same resistor!:eek:
I've been thinking of developing a fancifully wrapped open circuit. Instead of being placed in series, it'll work in shunt, out of the signal path. I'll be FAR superior to the Bybee. :D
se
open circuit? A "free-molecule oxygenated-dielectric" device surely? You could promote the device as using the subtle but spectacular properties of Brownian motion to absorb specific frequencies common to low-level odd-order harmonics typically generated from low quality power cables...
I can hear a difference already. You must have one of those thought-sensed pro-active enhancement things happening.
se
like this?:clown:
Dude, you want a job? :D
se
