500W PA amplifier with Limiter
hello everyone pls help me for XLR input with stereo bridge switch
This is simple XLR input circuit.
I suggest to use 2 way x-over with XLR input, and 3 position switch to select input mode (subwoofer, satelite or full range)
Clip LED light 10V before amp clip, that give visualable time light.
How do you know whether a 1us clip or a 100us clip or a 10ms clip gives a visual warning?
I don't know.
Maybe a prolonged series of 100us clips are visible, again I don't know.
I suspect some form of peak hold is required to show fast transient clipping. I seriously doubt that short clips will be visible without a peak hold facility.
For comparison purposes, a half wave of 20kHz is only 25us duration.
If only the top half of that half sinewave triggers the LED into conduction, then that gives rise to a 12us clip indication. Can we see that?
reactive impedance filters back through the stages.
If a 12device output stage is required to provide sufficient SOAR then the driver/s must also be designed to survive that reactive loading.
1pr of cold To220 are unlikely to have adequate SOAR to drive that many hot outputs.
i am falling asleep ..................................:sleep::sleep::sleep::sleep::sleep::sleep::sleep:
here is a sneak peek of the updated pcb still a lot of work to do will update tomorrow ....................and pcb size finalized 300mm X 68 mm..... max can be a bit less......
regards
sekhar
hi apexaudio
greetings should R23 BE 680 OHMS or is 330 OHMS correct will
MJE340 MJE NEED heatsinks
thanking you
andrew lebon
For BIAS setup R22 should be 1k2 instead 680R for triple darlington output stage, and R23 is correct 330 ohms.
Q5 (MJE340) must be on main heatsink with outputs.
Predrivers MJE340/350 can use smal heatsinks, but no need.
Hi Mr. Mile
i have built B500 in bridge mode, i use 1800va transformer ,rail voltage 63+/- vdc(45ct45) . caps 6 x 10.000/100vdc. are those caps enaugh for this ?
Stringent SOA needs in Class-AB are met with relaxed ones in Class-H.
For example, 1kW @ 2Ohms in Class-AB using 5200/1943 requires atleast 9-10Pairs with rails around +/-90V whereas only 5Pairs will do the job in Class-H if rails are split in say +/-55 & +/-95.
In a Class- AB reactive loading we have high dissipation because output device has considerable VCE + Ic across it hence heating very much, Whereas in Class-H, this VCE is quite less across the device for same output load, hence less heat and more headroom.
