APEX do you have a 2 band tone control made with transistors instead of opamps?
you posted a tone control circuit a long time ago with a tl074 quad operational amplifier).its working good.i attach a photo of it. do you have the same circuit with pcb but with 2 opamps? i have 2 opa2134 (dual operational amplifiers) and i want to use them.
I must check in my old projects, and I will share if I find some interesting schematics.
Excuse me, let me share schematics for the one I have at home.
Max.
Thank's, do you have pcb layout?
apex
hi apex,
i want to use this circuit but a little bit confused.Is it a 3 way xo or 2 way ?
12dB/oct activ X-over with balanced input and outputs for subwoofer (LO),satelite(HI) or full-range(FR). X-over adjust 50-250Hz, and level for satelite (HI).
hi apex,
hi mile,i have finished 100W Guitar Amp pcb,.wahat instead of 2n5638?
can I use this amp for bass guitar,thanks.
This is FET for mute amp when power amp on/off, you can use any similar FET or use amp without this mute circuit (without FET).
Yes this amp is for bass guitar.
hi apex,
This is 2 way x-over, but have 3 outputs: hi, low and full range.
Are you sure those 1N4007 are connected to the right place?
Shouldn't they be attached BEFORE the bridge?
Sorry, I didn't test this circuit, but I am trying to understand its behavior.
Thanks.
Max.
You have right 1N4007 must be connect to AC before bridge.
hi apexaudio
greetings can you tell which amplifier to use for active croOssover
1TREBLE 8 TO 18KHZ
2 MID 750 TO 8KHZ
3 LOW FREQENCY 150 TO 750 HZ
4 SUB FRE 40 TO 150 KHZ 50 HZ BOOST 24DB SUB GAIN CONTROL 12 DB
5 FULL RANGE OUT ALSO
only want amplifier 100 watts for hf P AUDIO COMPRESSION UNIT 100 WATTS
have finished crossover will test it today
thanking you
andrew lebon
1TREBLE 8 TO 18KHZ
2 MID 750 TO 8KHZ
thanking you
andrew lebon
sir,
please suggest or post a smiple 3 way crossover circuit with pcb layout.
Brazilian group buy
There is a brazilian group buy running, details here Grupo de compra para PCI de crossover - [Audio List] (in portuguese).
You may also send a private message to user MITCHEL, in this forum, who is responsible for that GB.
Max.
Hi,sir,
Max.
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
