Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy.
Joined 2006
Puffin,
At this rate, there does not seem to be enough interest to get a min of 60 of those units purchased and sold, which is needed to bring the price down reasonably. I am not against a group buy of these, or the R085s, but there needs to be a bit more demand.
Digikey says standard pacakge 30 (price break 60)
Standard Package 30
Category Discrete Semiconductor Products
Family MOSFETs, GaNFETs - Single
Series -
FET Type MOSFET N-Channel, Metal Oxide
FET Feature Depletion Mode
Rds On (Max) @ Id, Vgs 330 mOhm @ 10A, 10V
Drain to Source Voltage (Vdss) 500V
Current - Continuous Drain (Id) @ 25° C 20A
Vgs(th) (Max) @ Id 3.5V @ 250mA
Gate Charge (Qg) @ Vgs 125nC @ 10V
Input Capacitance (Ciss) @ Vds 2500pF @ 25V
Power - Max 400W
Mounting Type Through Hole
Package / Case TO-247
Packaging Tube
Supplier Device Package *
Send this link via E-Mail
ra7
Joined 2009
Well, I tried to replace the light bulb in the Delite with a CCS.
Unfortunately, my CCS circuit was wrong and I lost two devices
in the process. If only I were a brighter bulb... :eek:
Tea-bag and I spoke about doing another GB. I would be willing
to help with the GB, especially because I need those parts.
The IXTH20N50D is a pretty special part and you can build Paul
Hynes SE1 and CIRC1 amps with it.
I'm in for 10 parts, minimum. Anybody else interested?
Joined 2006
Do you have a price on the R085 depletion mode devices yet? I didn't see it in the spreadsheet.
I do not, I would assume they are going to be between 65-70 dollars a pair, based on the one's I bought earlier this year.
I will give them a ring and see what their current qoute is from this. Hopefully the price has dropped (for both SemiSouth's)
