500W PA amplifier with Limiter
as i type this msg i am currently asssembling the protection circuit for the b500. One thing came up to mind cant i use a single supply source for the protection board , may be a single 15-0-15 TF. Use a small sugar cube relay of 12V and drive 12V DC fans for cooling.
What changes need to done to incorporate a single TF.
regards
Sekhar
Protect for B500 use 24V relay and 24V fan or two 12V in series. You can use single transformer 2x18vac for two protect in parallel or use some other protect circuit. Your heatsink is not enough for full power but with two fans will work.
@ apex
i would load the b500 with higher rail voltage bec. i want to drive it for sub woofer two 1000watts speaker 4ohms. what would be aproximate no. of power transistor per rail at 140 vdc. do i need to changed the pre- driver transistor?
thanks alot sir
Use H900 for more power is better than upgrade B500, or B500 with TL072 class H step driver.
apex dual 18 sub
my apex sub, Fane 18xb loaded, painted with turboblue, nice bass
apex,
the scenario.
since i was using h900v2 pcb,i forgot to put jumper on neg. supply the one going to ir540
i already power up without jumper to neg. supply.Then after noticing the situation,i put then the jumper and power it up again,then the slight burning happen.it happen with zero v on the out.
I hope no collateral damage.
apex,
thanks i better do my testing tomorrow,i need some rest,winding a torroid is not that easy,adding 2x48 and 2x18 to my trapo.
now i got 96-48-0-48-96 ac
using 4x 20,000uf 75vdc
i got medium volt +/-62.5 dc
HV +/- 125 dc
will my psu work?for my b500 & tlo step
apex,
HV +/- 125 dc
Voltage is to high, you can winding more turns in series with primar to get lower voltage on secundar side of transformer.
