Puffin,
I only have one pair of the 6n50D2 left.
Those would be $16 shipped.
The others can be bought direct from mouser now.
747-IXTH20N50D
Did you say that you were intending to run another group buy? I have tried to order them from both Mouser UK and Mouser USA and it won't let me buy them from the UK!
Digikey says standard pacakge 30 (price break 60)
Standard Package 30
Category Discrete Semiconductor Products
Family MOSFETs, GaNFETs - Single
Series -
FET Type MOSFET N-Channel, Metal Oxide
FET Feature Depletion Mode
Rds On (Max) @ Id, Vgs 330 mOhm @ 10A, 10V
Drain to Source Voltage (Vdss) 500V
Current - Continuous Drain (Id) @ 25° C 20A
Vgs(th) (Max) @ Id 3.5V @ 250mA
Gate Charge (Qg) @ Vgs 125nC @ 10V
Input Capacitance (Ciss) @ Vds 2500pF @ 25V
Power - Max 400W
Mounting Type Through Hole
Package / Case TO-247
Packaging Tube
Supplier Device Package *
Send this link via E-Mail
Standard Package 30
Series -
Power - Max 400W
Packaging Tube
I have successfully blown a couple of the IXTH20N50D. Mouser is out of these. Digikey is the only source. Somebody should tell them that they could sell more if they sold each separately.
We should really do another group buy.
how did you blow them?
Well, I tried to replace the light bulb in the Delite with a CCS.
Unfortunately, my CCS circuit was wrong and I lost two devices
in the process. If only I were a brighter bulb...
Tea-bag and I spoke about doing another GB. I would be willing
to help with the GB, especially because I need those parts.
The IXTH20N50D is a pretty special part and you can build Paul
Hynes SE1 and CIRC1 amps with it.
I'm in for 10 parts, minimum. Anybody else interested?
I have started another spreadsheet for Depletion FETs and SemiSouth's devices.
I've been getting a number of inquiries, and I am out of all the devices currently.
Here is the sign up sheet link.
https://spreadsheets.google.com/ccc?key=0AnAnd3RI56NmdFdEczBUc2w4cGotOGVkOG10NmtwelE&hl=en
Do you have a price on the R085 depletion mode devices yet? I didn't see it in the spreadsheet.
I do not, I would assume they are going to be between 65-70 dollars a pair, based on the one's I bought earlier this year.
I will give them a ring and see what their current qoute is from this. Hopefully the price has dropped (for both SemiSouth's)
Hello , I have just 6 of them . And I would like a couple of pairs matched , they need it .
ra7 do you prefere them over the 6N50D2?
- Group Buys
- Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy.
