Tube-I-zator Professional PCB
yes everything is in right position, the mje350 is facing the dissipators side... here you have pics:
Oliver,
Regarding i/v resistors. I am thinking about the values. Did you try different values yet? I know that Lukasz Fikus's excitement about this circuit (which is why we're all making it, let's be honest) was with using 100R i/v resistor for a single dac, which is about twice the 56R value recommended here. What i the reasoning behind the given values please? I am due to fire up very soon (just waiting on the teralink X2 now :) :) :) ) and I have 27Rs installed in the Tub-I-Zator, but I'm not sure why not Fikus's 50R...
Excitedly, Lucas :D
Joined 2009
Oliver,
Excitedly, Lucas :D
The TDA1541A has a typical full scale current of 4mA. with the 56R you get a max. output voltage 224mV amplified by x100 (6N2P).
That´s more than enough output voltage :D
