I just ordered some 7591-S tubes for my Simple SE. After I ordered them, I examined the pinouts, and it seems to differ from the EL34, which I know works in this amp. Later, I realized the 7591 is a tetrode, and the 34 is a pentode.
http://www.diyaudio.gr/downloads/7591 S.pdf
Can I use this tube, or any tetrode for that matter, in this amp?
The data sheet says it's a pentode.
Can I use this tube
Not unless you make socket adapters, which is a pain. Easier to get something else, 6L6GC, EL34, etc.
jeff
Your right. Not sure where I got Tetrode from.
jeff
Probably right. I guess I will return them
