Michelson and Morley proved Einstein was wrong
This just in: Earth is actually flat.
Yes, it is flat if electronic devices are linear.
Different models work in different conditions. No one model exist that answer all questions, nor is convenient in all situations. For example, when you and your neighbor measure and mark a line to divide the land, do you use equations that include roundness of the Earth?
The same way, both geocentric and heliocentric models work, and each of them is convenient for different purposes.
Damn! No wonder everything I build for the house looks crooked! I was not accounting for the curvature of the earth!
Also, you probably did not think of precession! :D
By the way, ancient people knew well about precession, and observed it carefully!
Why?
Because they did not have cellphones to measure time (assume 30 years ago somebody asking, "What time is it now? I forgot my telephone at home!"), and they did not measure time in order to come to meetings about global warming in time. They measured time by astronomy, and the meaning of measurement was needed to adjust to environment... That's why they had so sophisticated knowledge about astronomy and weather changes. Because they did not have cellphones nor meetings. Actually, they had meetings, but used bells on towers to broadcast the time.
Religious discussions are verboten here unless they're about brands of capacitors. :D
We had not proven that God answers prayers or even that God exists. [...] All we have observed that when individuals outside the hospital speak (or think) the first names of hospitalized patients with an attitude of prayer, the latter appear to have "better" CCU experience
W. Harris, 1999
Complete rubbish - show your evidence (in this case reasoning) or shut up
If you make claims or propound a hypothesis provide evidence that that is falsifiable and can be repeated.
If those claims hold up under scrutiny - I will change my mind.
Skepticism just means one thing: convince me with evidence.
There is no bias. There is an suspension of judgment until a hypothesis can be falsified or not. If it cannot be falsified that still means only one thing: at present the hypothesis is not supported, the odds are in favour of rejecting it at present with the possibility of further investigation at a later date.
Atheism works on the same principle - show me any testable evidence that a supernatural being is needed to explain any physical phenomenon and I will change my mind.
Old texts are not evidence.
I've often thought about a science fiction story where mathematicians who were studying calculational algorithms for transcendental numbers suddenly found a long sequence of ones and zero that spelled out, "No kidding, I created the universe." Would that be taken as proof of a sentient creator? Or would that be taken as proof that in an infinite sequence, EVERY possible combination will eventually occur?
AX tech editor
Joined 2002
An infinite number of monkeys come to mind, hammering for an infinitely long time on keyboards, and suddenly, by coincidence, one produces Shakespeare's collected works. :D
jd
Ever read Sagan's "Contact"?
There the possibility of such proof is addressed.
Not the same concept exactly, but this did remind me of Athur C. Clarke's sory "The nine-billion names of god", in which Tibetan monks finally succeed in computing all the possible names of god, and hence --- well I won't spoil it for those who might still want to read it.
I posted this information over here
Anti-Relativity.com • View topic - Michelson and Morley proved Einstein was wrong
After I have rightfully dethroned Einstein, I will be the human race's ultimate prophet! Einstein was a runt and drop out that organized crime and communists used as their scam. I am true genius. I am infallible! Everything I say is true! Bow down to me. Worship me! Be my willing slave!
I will post my revelations on every message board on the internet. His followers will be destroyed and science will be what it is meant to be: truth, and I will be your final prophet.
Sepp Hasslberger: Challenging Einstein's Special Relativity: Herbert Dingle - Science at the Crossroads
