If there are internal fuses on the +/- rails for each channel then replace them with 10W 47-100 ohm resistors - on both channels. That will allow you to measure and compare quiescent currents. If the mains fuse still blows then you probably have a short cct bridge rectifier. You should be able to check the BR's in cct with a DMM.
A blown bridge is pretty common with an old amp.
Really? I find that to be a pretty rare failure - at least in the US.
G²
I have a Nakamichi PA-5E MkII.
The mains power fuse blows the second I switch the amplifier on.
I cannot see anything wrong inside the amp: no burned components, no appearent cold solder joints.
Do anyone have any idea on how I should proceed on this?
Thanks, Espen
Could be
The mains transformer,
Shorted bridge or diodes,
Shorted output transistors,
shorted filter caps (usually quite rare),
regards
Trev
