I finished my final tweak in Sakura Hybrid Tube Amp. I said final because, this is the best tweak I've ever heard. Every details from the music played from the cdp were unveiled from this simple but powerful modification. The ideas came from Mel and the guts of doing the experiment in Sakura was by myself. The You Tube video is just to give an idea on the improvement. However, the actual listening session is better sounding, of course.
Video Of Previous Tweaks:
YouTube - Sakura Hybrid Tube Amp and Harmony X77 Testing Part 2older video
YouTube - Sakura Hybrid Tube Amp (Choke modifications) with AN Super 8 part 2 previous video
Final Tweak Listening Tests Video:
YouTube - Sakura Hybrid Tube Amp (Final Tweak) Part 1
http://www.youtube.com/watch?v=gBGoe_pfMiU
YouTube - Sakura Hybrid Tube Amp Final Tweak Part 3
Thanks for viewing folks.
Note: The tweaks were supervise by rascal 101 of Pinoy DVD Philippines.
sounds awful to me.....through my shitty pc speakers, a mic, and then youtube encoding.
Yeah right, that's why you should use better one (PC Speakers). I use only Bose Companion 2 computer speakers. Better to try to use a good quality headphone. Thanks for the comment. You Tube Video is not reliable on listening test but can give some idea how it sound. At least it doesn't sounds like tin can.
youtube
Can your camera choose a higher quality recording? On my Sony it has the option for different video resolutions and audio encoding bitrate + frequency.
YouTube - audiobuzz's Channel
What a cool thread. Would it be possible to make clips pre- and post- tweak of the same track, so we can compare the sound? What kind of mains cables are you using? Sounds a bit like Shunyata Python in the bass.
Thanks for the comment. Sorry, I can't no longer do the recording without the tweak. The cables I am using is D.I.Y magnet wire gauge 21 for the signal and gauge 18 for the ground. You can experiment which gauge you prefer. Yes, the overall frequencies were improved after the tweak. But the sound is better of course in actual listening session.
Sorry, my Sony video cam is Digital 8 series. It's the last model before Sony went to Hard Disc type video cam. I just use Memory Stick Pro to record it.
I'm not going to go into the details but the tweaks were on improving the drive circuit of the transistor based power amp of the Sakura AV-200 hybrid amplifier. Essentially, it is a way to reduce the effects of Miller capacitance.
miller capacitance of which stage? this hybrid amp has got several stages....
Anyone has the schematic of this amp?
i do not have the schematic of the SS power amp stage but i copied the tube schemes:
this is the tube rectifier supplying +-6volts dc:
and this is the 6N2 cathode followers running on +-12 volts:
Anyone converted the SS power amp part to around 20 wpc pure Class A?
are you serious? this is a 25wat monoblock class A......careful what you wish for....
Mark Levinson ML-2 : HighEndClassics.com
I'm sure my eyes must be deceiving me, but that appears to be a PSU using 5Z4 rectifiers to produce 6V rails. It would be difficult to think of a sillier way to do this. It also appears to be a circuit using cathode followers running from a 12V rail. It would be difficult to think of a good reason for doing this. Unless, of course, power efficiency and sound quality were not aims of the 'designer', but pushing naive 'audiophile' buttons was the aim. In this it appears he has been hugely successful!
oh yes, DF96, i have had to deal with lots of those, i pull out the two 5z4's
and with just two resistors enable operation without those tubes.....
worse, each half of the 6n2's were left floating, i have had units come to me
with tubes lit but no sound, replacing with say 6bq7/6dj8 restored operations....
paralleled unused sections to avoid future problems.....
- Tubes / Valves
- Cheap Sakura Hybrid Tube Amp Modification
