I tried a Behringer UCA202, this suffered from unstable latency problems, meaning that it is impossible to set the markers for the gating (for gated F/r tests), as the pulse (and hence the reflections after it) move about by around 20mS. This can also be seen by doing a loop/rec with a sine and observing that the start of the sine moving about.
I have excellent results with SpeakerWorkshop and a desktop PC ( with CT4810 card) to carry out all acoustic and impedance tests.
Please reply only if you have experiance/had good results with a USB card and speakerworkshop.
I also have UCA202, it fail resistance calibration.I tried a Behringer UCA202, this suffered from unstable latency problems, meaning that it is impossible to set the markers for the gating (for gated F/r tests), as the pulse (and hence the reflections after it) move about by around 20mS. This can also be seen by doing a loop/rec with a sine and observing that the start of the sine moving about.
I heard that EMU 0202 is excellent.
