DAC-ASH (dac-end 2 up date)
This cricuit of DAC-ASH (DAC-end updat)
This circuit of DAC-ASH (DAC-end updat)
In this new PCB, I used six separate sources for each chip Salas AD1865, 74HC04, CS8414.
Please see diagram!
Forgive a beginner's question, would the DAC-ASH work without the I/V stage? Namely, would it possible to bulid using 1 PCB and "upgrade" later? or it has to be two boards simutaneously.
Yes! that is fine!
The IV stage i use parallel Composite-Triode, can use tube 6h6pi, 6h30pi, 6dj8
Yes, you can buy only the DAC and later put the I/V board or use other buffer board of your choise.
The boards are independent with their own power supply, you also can use the I/V board like a Pre.
Klaus
Klaus
In fact, my connection would be:
Computer -> USB (Teralink X2 -> SPDIF) -> DAC -> Pass B1 Buffer -> Class D -> 4 Ohm speakers
And
CD Player (SPDIF) -> DAC -> Pass B1 -> Class D -> 4 ohm speakers
I can build DAC only to make the above work. I can add I/V stage after DAC in the future. That simplifies the process a little bit and is more managable for beginners.
I tried to BOM the DAC over the weekend, but there are some components that I couldn't find over Mouser or Digikey.
Eaagerly waiting. Any plan for getting the chips? I saw a few group buy on the AD1865. Are we in a stage that reputable eBay sellers are there?
I need already the AD1865N-K, digikey only sell 15, therefor it´s good to make a group buy, perhaps together with other chips.
Many people just asked if it´spossible to buy at Ebay, and it seems one seller is good, but nobody stays without doubt and the most bought in group buy on Digikey, the only official source I know.
Klaus
The bom Of DAC-ASH
Parts List DAC-ASH
Resistor Vishay/Dale CCF50 1/4W:
470 Ohm x 1 R39
75 Ohm x 1 R41
680Ohm x 1 R40
Resistor Caddoc MK132:
200 Ohm x 2 R37,R38
Capacitor Vishay/BC
0.1uF/12V x 6 C26,C28,C30,C32,C34,C36
0.01uF x 2 C38,C39 (at digital input), C40,C41
68nF/63V x 1 C37
Sanyo os-con - electrolytic capacitors:
47uF/10-16V x 6 C24,C27,C29,C31,C33,C35
Chip
CS8414 x 1 U3 Cirrus Logic Inc
74HC04 x 1 U2 Toshiba
AD1865 NK, NJ, N x 1 U1 Analog Devices
Socket: 28 pin, 24pin, 8pin
Inductor: 120uH x x 2 L1, L2
Led: GREEN LED x 1
SPDIF: Transformer x 1 T2 Newava Technology S22083 or LL1572
Salas Shunt on The DAC
JFet Toshiba
2SK170 x 18 Q2,Q3,Q5,Q8,Q9,Q11,Q14,Q15,Q17 Q20,Q21,Q23,Q26,Q27,Q29,Q32,Q33,Q35 Transistor
Transistor Fairchild Semiconductor
BC560 x 1 Q10
BC550 x 5 Q4,Q16,Q22,Q28,Q34
Mosfet
On Semiconductor International Rectifier (IR)
IRF540 x 2 Q7,Q12
IRF9540 x 10 Q1,Q13,Q19,Q25,Q31,Q6,Q18,Q24,Q30,Q36
Electrolytic Capacitors / Rubycon ZLH or Panasonic FC
220uf/16V x 6 C3,C7,C11,C15,C19,C23
2200uF-4700uF/25V x 6 C1,C5,C10,C13,C17,C21
Capacitor Illinois Cap & Wima, etc...
0.1uF/25V x 12 C2,C,C6,C10,C14,C18,C22,,C4,C8,C12,C16,C20,C24
Resistor Vishay / Dale CCF50 1/4W
10 Ohm x 6 R4,R11,R16,R22,R28,R34,
47 Ohm x 6 R5,R11,R17,R23,R29,R35
100 Ohm x 6 R3,RR9,R15,R21,R27,R33
220 Ohm x 12 R2,R8,R14,R20,R26,R32,R6,R12,R18,R24,R30,R36
Resistor Vishay / Dale CCF50 2W
33 Ohm / 2W x 6 R1,R7,R13,R19,R25,R31
Led Green Led x 18 L1-L18
Diode 1N5819 Schottky Barrier Rectifier
40V x 24 D1-D24 . http://www.oup.com/us/pdf/microcircu...n5817-fair.pdf
Trimmer Fairchild Semiconductor
VR 1K Ohm x 6 VR1-VR6
Tranformer
9-12 V/100-200mA x 6
The Bom IV stage for DAC-ASH
IV stage for DAC-END
Composite-Triode
1.Resistor
Resistor 2W
R1,R31 = 22R/2W
R16 - R20A = 18K/2W
R32 - R36A = 18K/2W
Resistor 1/4W
R22,21,37,38 = 200R
R23,24,39,40 = 470K
R25,26,27,28 = 2K
R41,42,43,44 = 2K
R29,30,45,46 =220K
R52 = 10R
Resistor RELAY
ALL 1/4W
R47 = 220K
R48= 1K
R49 = 5.6K
R50,51 = 4.7K
2. Caps
C16, 22: 47uF/450V
C19, 21 ,24, 26 = 220uF/16V
C19,20,25,26 = 0.1uF
Caps -output:
C17, 23: 0.47 - 1uF/450V (Jensen, Audicap, M-Cap…)
Caps RELAY
C28: 47 - 220uF/12V
3. DS2Y RELAYS 5v X 1
4. Transitor
Q1: BC337
5. IC: LM311
6. Diot: D19, d20 = 1N4007 or better
7.Tube: V1, V2 = 6H30Pi, 6H6Pi, or 6dj8 x 2
8 .
Tube Socket 9 PIN X 2
9. PCB I/v stage X 1
Note:
1. All resistor 1/4W or 1W
2. R1, R31: 22R/2W. R16 - R20A use 2W. R32 - R36A use 2W
2. The delay time : 0.45 minutes
Use Tube:
1.Tube 6H6PI:
+B = 270V. R22, R21, R37, R38 = 400R - 470R.
2.Tube 6H30PI:
+B = 230V. R22, R21, R37, R38 = 200 - 220R.
3.Tube 6DJ8 or 6H23:
+B = 200V. R22, R21, R37, R38 = 280R - 300R.
* R16 - R20A = 47K/2W .
* R32 - R36A = 47K/2W.
Parts List Salas Shunt for iV stage
1. JFet:
2SK170 x 1 Q4
2. Transistor
2N2906 x 1 Q5
MJE 350 x 1 Q2
3. MosFfet
IRF9610 x 1 Q1
IRF840 x 1 Q3,Q15
3. IC
LT1084, 85 x 1 U1
4. Capacitor
220uf/450V x 2 C4,C5
1uf/450V x 2 C2,C3
100uF/25V x 1 C1
4700uF/16V x 2 C10,C11
470uF/16V x 2 C12,C14
47uF/16V x 1 C13
0.1uf/16V x 5
5. Resistor
Resistor 1/2W 3.3 Ohm x 1 R7
47 Ohm x 2 R9,R10
200-220 Ohm x 1 R13,R2,R6
6.8K Ohm x 1 R14
Resistor 2W
33 Ohm x 1 R1 for Tube 6H6Pi and 6H30Pi,
47 Ohm x 1 for Tube 6Dj8
5.6 K x 1 R5
120 K x 1 R4
100 Ohm x 2 R15,R16
Resistor 5W
56K x 1 R3
6. Trimmer
2-5 K Ohm x 1 VR2
500-1K x 1 VR1
7. Led Green Led 3 D2,D3,D4
8. Diode
Diode 4A x 4 D13,D14,D15,D16
Diode 1N4007 x 2 D17,D18
Diode 1n4007 or better x 4 D9,D10,D11,D12
http://www.datasheetcatalog.org/datasheet/Sanken/mXqxxyz.pdf
Diode Zenner
1n4742 or zener diode 6- 12V
TRANFORMER
SALAS SHUNT 1 0-200-250V/100mA
Filament x 1 0-8V or 0-9V/2A
Heatsink
10W x 2 Q1,Q3
5-10W x 1 U1
Jump
3 x 2
Quanghao, the circuit for SSHV posted above lists for D5 & D6 - 1N4142A but the BOM (on page 179 of the original thread) says 1n4172?
I suspect the part we want here is 1N4742 or 1N4742A a 1W 12V Zener Diode....
Is this correct and if it is could you please make the corrections to the circuit so others don't have a problem.
Thanks!
Hi! Im sorry
that is I m wrong, 1n4142 is correct!
1n4742 and 1n4742 is one, this is zenner diode 12V
My be not need this Diode, if you can not fine it , you can change Zenner diode from 6.8V to 15V, 1/2W.
SSHV many time not need this diode, but It is still very excellent!
