Recommend enclosure for ED 13Ov.2 Subwoofer
I was given this driver by a friend, is it a good subwoofer?
Would it be suitable for a tapped horn or transmission line loading?
Thanks a lot!
Qts: .28
Qes: .30
Qms: 3.3
Fs: 21.00Hz
Re: 8.3
Vas: 176L
Mms: 195.0g
Bl: 21.70T*m
SPL: 89.1dB
Sd: 545cm²
Xmax: 18.3mm
Voice Coil: 62.5mm
Magnet Width: 6.750"
Cutout Diameter: 11.000"
Mounting Depth: 6.600"
Weight: 25lb
Total Height: 7.600"
Displacement: .07 ft³
Outside Diameter: 12.375"
I had the opportunity to measure the t/s parameters of a 13Ov.2 about two years ago, using a WT3. t/s specs were nothing like the published ones. They were as follows:
Re: 7.256 (coils in series)
Fs: 28.3 Hz
Qts: 0.456
Qes: 0.496
Qms: 5.697
Le: 3.454 mH
I suggest getting the specs for your driver measured (or measure them yourself - see my site for a means to do this) before committing to anything like a transmission line or tapped horn.
...running the numbers makes for a driver NOT suited to a TL nor a vented alignment...
:eek:Don't agree, As I found this driver suitable for a T-TQWT, thus a ported or a TL should work too:
b:magnify::)
Just repeating my suggestion. You might end up with disappointing results if you build a sub based on either the published specs (or my measurements) and it turns out that your driver isn't a close match for either.
At the very least, measure Fs, to see if it's closer to 21 Hz or 28 Hz.
