Johnferrier, I am fairly sure that either makes a pretty good recording, by today's standards. However, WHY would someone buy a record for about the same amount as these recorders cost today? Collector's madness?
No matter what the ads say, or public opinion, there is a difference between what we did to record audio, and what many people have available to them, today.
Still, I bought a Sony radio, yesterday, on Dick Sequerra's recommendation. I couldn't resist the price/performance ratio, and it is always good to try new technologies, but keep in mind that IC's still don't do what tubes or discrete circuitry does. I wish that it did.
"It's worth the price!"
Recently, I followed bidding on a Sequerra Model 1 FM Tuner. Winning bidder had to make own arrangements for pickup (in CT) and the description said "don't know if it works properly . . ." However, it fetched $2,045.99.
Model 1 --> ebay
Model 1 --> ebay
I have a Marantz 10 that I really love, but I have to fix it to make it useful for listening properly, again. Dick recommended the Sony, and told me that it was based on a very different technological approach than his early designs, and that he was impressed with its performance. What I am really concerned about is what analog IC circuits, whether external to the RF module or internal, and the output coupling caps. This is where many of these 'cost effective' designs fall short.
The Sony PCMD50 96 kHz/24-bit recorder is a decent portable recorder? Low noise levels are dependent on the quality of microphones. The recorder up from this--the Sony PCM-D1--uses Scott's AD797s.
Amongst other things, I have in mind things like what Bear wrote about comparing mic'ed live (outside ambient) versus recorded ambient.
For not much more, the Korg MR-2 records DSD (that can be save to a SA-CD format).
Really?
I bought a Fostex FR2-LE based on this comparison. I liked the ability to record many formats.
Avisoft Bioacoustics - Microphone Input Noise Comparision
Well, not quite . . .Really?
"Playback of DSD Discs is currently limited to Sony VAIO PC's/notebooks, non-VAIO PC's running Windows Media Player 10/11 (with DSD plug-in), PlayStation3 and the Sony SCD-XA5400ES and SCD-XE800, whereas the SACD audio discs have much greater hardware playback support."
I thought I read something about some older models of Vaio computers having the ability to burn SA-CD.
That comparison is helpful. I noted that the Korg recorded DSD, but the dynamic range wasn't any better than the Sony recorder.
>Only thing that really works to stop the hum is
>the 0.1mH ferrite bead choke.
>So, I think you might be right Hitsware,
>about the demodulated high frequency
>noise causing the hum problem.
That is one place where jfets shine ....
Don't demodulate like bipolar ....
Obviously (IMO) because they are reverse biased ...
Will jfets work in your circuit ! .... ( maybe just for the input ) ?
The heavily digital one for ~$100
that runs sorta hot ?
I'm thinking of that option also....
http://www.crutchfield.com/S-y6IPAJbNn1D/p_158XDRF1HD/Sony-XDR-F1HD.html
The other John talkes about demodulation so i thought a cascode could shift that problem up in frequency. I also found that cascodes seem to have better DC stabillty then transistors that are left alone. That depends then mostly on the bias scheme of the cascode transistor. I mostly use Leds and RC filtering or low noise precission references when i try to do something better.
I could do jfets, if I can find p and n channel ones. I need positive and negative voltage rails.
I used the 2n3906 since I had them on hand and they're cheap and it has a nice complement in the 2n4904. My goal is to build a cheap and simple design with the best possible performance. I want it to be shunt.
It's going to power a jfet single ended preamp design, maybe cascode. Haven't worked out the details on that yet.
I'm also going to experiment more with the active, feedback shunt. It was cascode, but not the current source. It was the same.
John
John Curl said:I suspect that a complete 're-think' of the design would improve things, rather than adding more stages.
Thanks John!
I don't why people here dislike my RF choke fix to the problem. It seems to work good, time will tell. But, I agree, it could be better and I'm not done yet.
I should fix my noise amp first. It's Dennis Collin inspired but I had some problems when constructing his exact circuit, entirely my fault I'm sure. Probably wired something wrong. Mine seems to be a noiser that his. His output noise was -135dBv I think. Mine just -120dBv, -125dBv on a good day.
The source of your problem seems to be the active current source. If you have fixed it, then no problem, if not, complicating an already primitive circuit, isn't going anywhere. With such circuits I usually find that a film cap bypassing the input is really important. I have found that 5000 pf mylar is OK, for example, and probably removes a lot of TVI that is picked up.
I agree, complicating a circuit that doesn't work isn't helpful. My circuit seems to work good though. But, I think, I'll take Hitsware's advice and turn the current source around and switch to NPN devices so that only the collector "sees" the RFI,TVI noise. I'll try the 5000pf mylar cap too. I don't have mylar on hand ... is that important or just adadequate for the job?
I'll start another thread if I decide to keep discussing this, so I won't disrupt your thread.
John
Hi John,
Did you get the Sony XDR-F1HD? : http://theaudiocritic.com/plog/index.php?op=ViewArticle&articleId=35
That tuner shows the (future) promise of high-speed RF DSP, and Sony utilized that to great advantage, making the IF bandwidth dynamically variable depending on signal strength and adjacent-channel interference. From an engineering standpoint, it is the first tuner to offer those benefits. A a broadcast engineer, I can appreciate how much benefit can be obtained from a correctly aligned IF filter section, and the DSP alignment seems to offer many improvements over a multiple ceramic-filter IF selection topology, if only from a correct alignment perspective.
A fellow amateur operator, Brian Beezley spent quite a bit of time dissecting that tuner and suggests modifications:
Sony XDR-F1HD
From a purely technical perspective, the tuner is an amazing feat, but after auditioning one I did not buy it (I may still if Bay offers one up to me cheap). As a radio engineer I know what the sound of processing used in the major stations is like. The station I set up and maintain is using an Orban 8500 set up to do JUST AGC. No individual frequency band processing at all. So, minus the long-term dynamic range modulation, it sounds pretty damn transparent. When listening to it at a good signal strength (70dBu reception area) I thought that for my tastes (emphasis on MY) it sounded grainy. Some sort of grit or grunge is added to the signal, compared to the best analog tuners I own. On the other hand, it's RF performance is nothing short of amazing, and comes close to, or equals the best analog tuners.
I think that this Sony tuner represents the first wave of tuners utilizing digital IF processing to replace expensive and difficult to align analog IFs based on ceramic filters, and like the CD format, will get better with time as the technology allows for higher-speed DSPs. I don't know what IF oversampling is possible with the NXP TEF6730/SAF7730 chipset, but I'm sure future generations will be capable of better performance.
Until then I will continue to use my Kenwood 600T at home. It may be old (1980), but it sounds extremely sweet with a decent signal.
Howard Hoyt
CE - WXYC FM-89.3
UNC Chapel Hill, NC
Johnloudb - there are a number of excellent regulator circuits already designed and working. Some are discussed on this forum. Some have pre-made pcbs available, some are ICs (three pin variety?) that you can just use... I'd start with that myself.
John Curl and everyone else - if you didn't spot it already, a bit of
audio history:
http://www.diyaudio.com/forums/solid-state/171449-big-electro-research-class-amp.html#post2264972
_-_-bear
audio history:
_-_-bear
hhoyt said:Hi John,
I know you meant the other John, but I did buy it. And, it worked good for FM, however, whenever it finds and HD radio signal it switches automatically to HD radio. I read the manual and can't find a way to disable HD radio. If someone can tell me how, send me a PM please ... I cannot even listen to it in HD radio mode.
bear said:Johnloudb - there are a number of excellent regulator circuits already designed and working. Some are discussed on this forum. Some have pre-made pcbs available, some are ICs (three pin variety?) that you can just use... I'd start with that myself.
Yeah, I've seen some nice ones here. I just enjoy designing my own stuff ... that's the fun part for me. I've designed a few regulators and preamps and my ears have no complaints.
John
- Member Areas
- The Lounge
