QSC PL380 amp
Get More Power Out
Please tell me a shortcut to break the power level .chinese are spend The Mid-autumn Festival joyfully now, i send everyone mooncake picture,thanks!!
When you lack experience and design criteria in a particular technology field, and yet you want to release a product very badly, you have to adopt popular ideas, there is no time for innovation. Some will be good, some won't.
From the technical point of view, a RC zobel has never been strictly required in post-filter feedback class D amplifiers, yet everybody seem to be using one. The limitations are being inherited too, there is no will to overcome them... ;)
Theoretically, the zobel improves phase margin and allows for slightly higher open loop gain, and thus, lower THD. In practice, it does not provide any substantial advantage without burning a lot of watts, exactly the opposite of the main goal of class D.
The zobel also helps to damp output filter when the amplifier clips and the control loop is not active, but there are other ways to do that wasting far less power.
Share pl380 pictures here
Hi,everyone!
Look this thread ,nice meeting friends here again.
we have developded some stable little amp like QSC PL380 now,They can deliver out2kw / 4kW rms power out.
Share pl380 pictures here.
Some friends want to know SMPS theory,I suggest you can look for some magzine about series resonance,
SMPS and AMP all in one
We think output stage and smps have personality and we believe it should excellent choose.
I am deeply admire QSC engineer,only them design the integratedwhole amp.
Usually Engineers divide the amp two parts:power supply and amplifier,so the two parts can not accord works .Even some factory use one power supply PCB and one amplifier PCB in one amp.In some way I think it faulty design.
Because we think amp like one energy convertor,small signal input,biger power output,should all in one and cooperative work.
Because Patrick Quilter is unable to make his amplifier stable at open loads:D
His fears are genuine, what will happen if HF oscillation occurs.
So he puts a 200W 10R Vishay TO-247 Resistor in the Zobel to sustain the dissipation:p.
Taught so too ;)
Thanks for confirming me this.
It's hell when you are forced by the company to put on the market a product that is not stable. Management can kill good products because of their greed. I have the same problem at my workplace. Bad products are corrected with nice presentations and nice casings, preety collors and so on to steal the eye of the buyer.
