Rod Elliot P.68 Phase?
Hi all,
Having read numerous posts on the forum I have come to learn the importance of linear phase response and would like to take the audiophile route through my system.
I recently realised upon testing with a scope my cheapish subwoofer amplifier has very poor phase response deviating to almost 90 degrees at 120hz even if dc coupled. I found the capacitors which cause the problems but they are required for the amps stability and as the amp has had numerous faults and is running on virtually 0 bias current, I was looking into Rod's design substituting the MJ transistors with 2sc's.
I have emailed Rod but received no reply, could anyone advise from the design if it has a reasonably linear phase response with minimal deviation from 0 degrees (if anyone is able to deduce such information)?
300/500W Subwoofer Power Amplifier
Hi all,
Your subwoofer amplifier must have a crossover, the phase shift is normal.
the input high pass filter 4u7F & {2k2+22k} is sufficiently low to allow all your bass and sub-bass signals to pass and yet still block DC and ultra low frequency.
The high pass built into the Negative FeedBack route cuts off a little higher. This should be lower than the input filter, change C4 to 180uF or 220uF.
Similarly C5 could usefully be a bit bigger, maybe 150uF.
Thanks for the advice with Rods design, from what people have said I gather Rods design will definitely have a linear phase response for atlest the lower frequency band (all "bass")?
My latest post was just to show the current manufactured design as Richie said it may be faulty - if the phase shift problem could be fixed I may put off building rods design for a while, ie if anyone can spot a flaw causing the phase shift in the original design that would be great I was resigned to having to totally make a new amp.
Thanks alot
I measured the phase shift just by connecting different scope channels to the IN and OUT. The shift was easy to see.
Thanks wahab, I assume those modifications are to help keep phase deviation down if I were to build the new amp?
Yes, it will reduce the phase shift to almost zero in the
low side of the audio band and settle the 1/f frequency
corner.
Increasing even more these caps value would be counter
productive in respect of the latter caracteristic mentionned.
