hi apexaudio
greetings today powered amplifier on series bulb is glowing
` very weak audio voltage seem's to be collapsing both high and low can u please give some tips on how to find faults
thanking you
Andrew lebon
thanking you
Andrew lebon
I can't see all conection from PSU, do you conect GND from PSU to input GND with separate wire? Do you have wire jumper on coper side pcb? Can you post lighter picture.hi apexaudio
thanking you
Andrew lebon
APEX H900 pcb is in post #297Hi, Your version of pcb available?
Fan must be for 24V, TL084 can be used instead TL074, some transistors was replaced?Here are gathered on your PCB
Replaced some of the denominations;Fan must be for 24V, TL084 can be used instead TL074, some transistors was replaced?
2n5551-bc547
2n5401-bc557
bd139-2sd880
Control relay-2n5401-2sa1020
Yes, but two LED in series not parallel.apex,
sir, without the presence of NSL32 on board, replaced with a normal LED and LDR enclosed in a black pipe, can i add another LED in parallel as clip indicator???...that would be two LEDs, one as clip limiter and another is clip indicator...
tnx...
That's ok you know pins layout.Replaced some of the denominations;
2n5551-bc547
2n5401-bc557
bd139-2sd880
@andrewlebon
I can't see connection between HV GND and MV GND on PSU. Check PSU without connecting amp.I can't see all conection from PSU, do you conect GND from PSU to input GND with separate wire? Do you have wire jumper on coper side pcb? Can you post lighter picture.
Yes, but you need 4 35amps diodes or 35amps bridge recifer (gretz).apex,
sir will my psu rated 55vac 0 55vac @25amperes, 4 10,000uf/100v caps and 2 35amps diodes do the job for b500???...tnx...
maybe he means 35a bridge diodeapex,
Maybe for dual mono.maybe he means 35a bridge diode
400W on 4R load, 500W with 0,5% THDapex,
engel,
what i mean was 2 35amps/400v bridge diodes...how much power would the amp give me???...tnx...
With 2X60vac you have 500W on 4R with 0,1% THDto achieve maximum 500w of power on 4r load, i must then raise my rail voltage up to +/-90vdc... or come up with a +/-70vac @ 25ampere transformer...
+/-90VDC is for 650W on 4R, but I not recomended
2x70vac is out of safe operation
- 900W H-class PA Amp with Limiter
