Quanghao:
I meant to say
Pin 7,18,22,24 are all 5V
Pin 21 is at ground.
Bob
yes! 21 to GND:
I think Your CS8414 have problem, when you turn on, the LEd is on, that is ok.
you se circuit here:
DAC End 2 - the AD1865N-K with single ended vacuum output stage
I'm trying to wire up the following R-core to acheive 8.15V..
R80-36 260-230-0-230-260(90mA). 2.5-0-2.5(3A).(3.15-0-3.15)X2(3A)
I read further back in the thread that I needed to use 2.5 + 2.5+ (3.15) parelled, I dont really want to guess what this means and would rather ask the best way to wire it up.. As If I were to guess I'd connect the 2.5 and 2.5 and join the 3.15 wires together, which is most likely wrong?
Boards received
Hi Quang Hao,
I have received 2x PCB Salas shunt for DAC today.
Thank you very much.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hi Quang Hao,
I just made a payment USD37.26 via paypal to quanghao168@yahoo.com.vn for 2x PCB Salas shunt for DAC.
Thanks.
Hi Quang Hao,
yes! 21 to GND:
Quanghao:
You were right. I put together another CS8414 and placed it in DAC. Now the LED is lit without anything plugged into the SPDIF. Turns off when I plug signal in.
Problem - still no music
The jumper is in place.
6.21V on filaments.
285V on tubes.
Where should I look next?
Best
Bob
Thanks for your help
Cool, check for a wave output across the DAC board then, eliminating that. If you still get nothing through that then follow it back, through to the other side of the inductors, past the 200r's to pics 21 and pin 4 of the ad1865.
If you get nothing there, then i have no idea, as i don't understand the digital side.
Can anyone advise me how to wire up this R-Core for the I/V Stage?
I'll get the scope on it during the next couple of days. I was optimistically
Hi
I'm no expert, but would have thought the following.
FAO apelizzo
a few pages back (post#2119740) you posted an alternative i/v stage. Any chance of a bit more info (better schematic/external links) on this for who might be interested ?
Obviously, don't want to spoil this thread too much.....
TIA
Hi
FAO apelizzo
TIA
The alternative I/V stage I posted was a single ended differential circuit with cathode follower output buffer. The gain of the circuit is not enough unless you increase the value of R23-24 from 200R to a little more enough to obtain 2Vpp output. I don't think 200R value is critical here. If you want I can post more info.
LC Filter
I would like to know why the LC filter (like the AudioNote DAC) has been adopted in this project to roll off frequency before 20KHz. I know that's an option, but what is the benefit other the short to floor residual digital noise?
Did anyone tried with and without it?
SSHV upgrade
It would be good idea to upgrade the power HV supply in this project.
Quanghao is this in your to do list?
In my previous DAC I used shunt PSU instead of expensive Jensen cap. I guess it makes the difference
Heater power supply also needs to be improved. Perhaps constant current on heater with different arrangement.
- More Vendors...
- Quanghao Audio Design
- OLD THREAD DAC End by Andrea Ciuffoli
