esp project 101
HI
It is really a great sounding amp .
Yes you have to purchase the pc boards to have access to the real schematic .
The board are good quality and very cheap . Rod will help if you have any question even if these will be your firs project you can be sure you can finnish it .
any body has a schematic with components values for esp project 101
Yes
You need to buy a board from Rod Elliott to get the proper schematic.
Concur
Agreed these amps kick butt,Period !! I built two,two channel hi-power version.They sound excellent....Do yourself a favor "buy the boards"
;) Dave
will do !!!!
finally we will buy the project 101 .......the truth is that i dont need to construct the project ...i only want to compair it with legend 8 and legend 4 me and sakis east_electronics@yahoo.gr working on
project 101 is not quasi like legend but drive should be arround the same ...we both like to investagate that .....
will see....... all ready contact rod elliot and now making shiping arangements
thanks
sierramike
we are friends
and started to construct legend 4 for sakis and legend 8 for me
we run int the same problems ....both
probably dr bora missed that rail voltage was arround 66 volts or sakis or both ..... whatever any way ...this circuit cannot operate as is in this voltage .....
we both now look if there is any chance to make any changes to get this running safelly .....
the truth is that we are constructing amps together ...we have to make about 15 each ......we have to construct in various forms stereo or mono or amplified speakers etch etch
we have to make all this and give almost for free to school for kids with special needs and used in music and multimedia courses for some really talented kids....
we are getting kind of rush now cause a) we are late and b ) we spended a lot of money ( that doesnt belong to us ) in making pcb and mosfets for a project that doesnt work .....
neet eee.....
ESP Project 101 - Lateral MOSFET 2SK1058 + 2 SJ162
i heard is very musical and extremelly powerfull
thanks
:) This is one good mosfet amplifier
:) No doubt about it
if we have some basic knowledge we can easily figure out components values
we probably have 200-300 persons at this forum that can do this
As this amplifier is very basic with few transistors
is easy to try some different current settings
for the different stages: input - vas -output
and see what works well.
As can be seen in this schematic Rod Elliott even tells us which transistors he use :)
2SK1058 and 2SJ162 should be possible to buy almost every country.
They are Lateral MOSFET from Japan.
Regards Lineup :cool: Lineup Audio Labs
can anyone plzzz give me the real values of the components of this amp....????
Buy a board from Rod and you will get the info you seek. Otherwise I doubt anyone that has the component values will surrender them. Its kind of a promise we all made to Rod upon the purchase of his boards. The component values are intellectual property of Rod Elliot.
The reccomended Exicon MOSFETs don't appear to still be available:
Lateral Mosfet
unless the ECX10N20/EXC10P20 are also suitable? The Hitachi/Renesas devices seem to have dissapeared completely from UK suppliers now.
Perhaps these would be suitable:
ACD100NSD Lateral Mosfets - Class-d Limited
ACD102PSD Lateral Mosfets - Class-d Limited
Not sure how specific the devices need to be in this design.
I've built 3 using the bought PCB. It makes for very easy construction and it certainly is a good amp, great for bass especially :)
XEAGLEKEEPER: :up:
riddickbt: It´s just US$20/pcb...
About the rest from XEAGLEKEEPER post, please see Rods - ESP HP...
I've built 3 using the bought PCB. :)
Hi Dr. EM,
I've built only two (Mom & baby)... :crying: ;)
Yes, it certainly is a very good amp... also very good for mids!
Ex-Moderator R.I.P.
Joined 2005
Hey, I might choose to build this amp
reason, I have two monster trafos, 2x 38V/25A
and I have 8 pairs of Renesas, thightly matched
also have 4 big heatsinks
seems all I need to buy is supply caps, and a few components
I would like to build with 4x output pairs
hardwired output stage
and I will ofcourse buy board(schematic and boom)
Any reason not to ?
