FS:ultimate attenuator kit for audio,balanced/single-end
This is a great KIT for those DIYers who want to build high-end quality audio DIY projects. It based on the following highlights:
R-2R current switching technology
High precision SMD resistors
High performance Analog switches DG413DY
Ultra-high performance Op-Amp AD797AR
Ultra-pure voltage regulator on board
Ultra-low noise
Ultra-low distortion
Low output impedance
Micro-controller with remote handset
4 input sources selectable
Wide range attenuation -96dB~0dB in 1dB/step
With this KIT, you can build a HI-END preamplifier easily ^_^
Price :
$250 single-end stereo
$450 balanced stereo
paypal accepted
airmail registered included
More information about my KITs ^_^
http://www.diyaudio.com/forums/swap-meet/135458-new-project-r-2r-attenuator-remote-control-v2.html
http://www.diyaudio.com/forums/swap-meet/144038-new-remote-volume-controller-10-sets.html
http://www.diyaudio.com/forums/swap-meet/130302-share-remote-volume-control-kit.html
attachment.php
attachment.php
attachment.php
USER MANUAL is ready, drop me an email ^_^
bbp6604560 at hotmail.com
orthoaudio at hotmail.com
thanks
Is one of the inputs a bypass input(signal in will be uneffected by volume control) so It can be used as a home theater-bypass??
sorry CustomHT, I reserved no bypass input,because the volume control is excellent enough for any audio applications ^_^
the input voltage range up to 10Vrms when you set the attenuation to 0dB,the module still provides low distortion signal
and even it accept 20Vrms input signal when you set the attenuation to -20dB
I most applications,the module can be deemed to a straight line when you set the volume attenuation to 0 dB
maybe a pass through is the best, but maybe w/o a pass through is no the matter ^_^
thank you
test performance added
Test result added
fully THD+N VS AMPLITUDE test
750 ohm loaded @ each phase of balanced
A-weighting
1mV to 16Vrms sweep
the blue line is the Residual performance
the green line shows the performance of this KIT
attachment.php
the gragh shows that the THD+N of R-2R VCS KIT is -110dB@5Vrms,only 1uV residual noise!
