The Pass Pub: The High-End Off Topic Thread
Greedy Jan? Na, he is probably giving them away right now. Nice pic.
Trying to catch up on whats goin on here at DIY, I agree with you ZM (Not a lot;-) A thing that could be fun, would be to hook up a BA2 gainstage to a F4 he-he. Anyway, I hope the next frontend will be a high voltage version that can swing enough output to pull all the juice from those BA output stages. That would even be nice for the poor F4 builders without a Pumpkin.
Official Court Jester
Joined 2003
Joined 2003
Joined 2003
same toob , slightly different heaters ; ECC88 is 6V3,365mA while PCC88 is 300mA,7V6 ;
in european toob nomenclature , first letter :
E means 6V3 is primary value for heater
P means 300mA is primary for heater
considering that I'm always using CCS for heaters , I just don't care too much ;
in first case , I set CCS to have around 6V3 at heater , in second case to have 300mA through
edit :
you asking for EC (PC) or ECC (PCC) ?
first case - just one C - means one triode per bottle
second case - two C - means two triodes in same bottle
Joined 2003
I think that JH is looking at as from above ........ certainly laughing ..... even ROFL here and there ;
he was nice lad ...... and I'm thinking that he certainly still is , somewhere .....
regarding da toobz - you really need PCC or ECC for that circ - matching issues are much smaller if we are talking about two triode systems in one bulb ........
these types you have are useful , but not so - in this case
