I am attempting the following mod project:
Photo 1 of 17, Rotel RQ970BX HFW -Andy Grove upgrade
My question is - can I use a pair of OPA627AP's or AD843JNZ's instead of the specified AD743JN without any other changes to the project instructions? They seem to be a lot easier to get hold of.
To be honest, I know nothing about electronics - but I can solder and I can follow instructions. I've got as far as mounting the existing op-amps into sockets without destoying anything
Thanks in advance for any help,
Tim.
Tim.
Check the pin-outs on your replacement set of OP-Amps...the pin-outs MUST be exact. Check for specifications also.
Are you replacing these Op-amps for a "cleaner" sound??
The general characteristics of Op-amps are:
Infinite input impedence
Infinite gain
Dead short output impedence
Infinite frequency capabilities
Obviously these characteristics are impossible..more like 10M Ohms input, 200K gain, 100 Ohm output, 50K Hz "F".
Although it doesn't quite hit the "ideal" characteristics it is close enough.
There is a fifth..but I have forgotten.
An Op-amp without negative feedback will crank the gain up so high as to slam an AC signal to the positive and negative PS rails effectively making a square wave generator.
Search Wiki-pedia for Op-amps...great things these little silicon beetles!
____________________________________________________Rick....
Infinite gain
Thanks, I appreciate your reply.
I did take a look at the datasheets before posting here, but I have to say that I'm a bit out of my depth, which is why I thought I'd seek some expert advice.
From the datasheets, the pins for the different chips are described as follows
AD744JN (existing chip)
pin1 NULL/DECOMPENSATION
pin2 -IN
pin3 +IN
pin4 V-
pin5 COMPENSATION
pin6 OUTPUT
pin7 V+
pin8 NULL/COMPENSATION
AD743JN (recommended in the mod project)
pin1 NULL
pin2 -IN
pin3 +IN
pin4 -Vs
pin5 NULL
pin6 OUT
pin7 +Vs
pin8 NO CONNECT
OPA627AP
pin1 OFFSET TRIM
pin2 -IN
pin3 +IN
pin4 -Vs
pin5 OFFSET TRIM
pin6 OUTPUT
pin7 +Vs
pin8 NO CONNECT
AD843JN
pin1 BALANCE
pin2 -IN
pin3 +IN
pin4 -Vs
pin5 NO CONNECT
pin6 OUTPUT
pin7 +Vs
pin8 BALANCE
I was unsure whether the differences in this table were significant, or even possibly just terminology differences (especially seeing as the AD743JN is the one being recommended to replace the AD744JN).
As you can see, I'm sruggling with the basics, so it worries me a little when you say to "also check for specifications"! I was hoping some kind soul would give me a yes or no as to whether these can be used as drop-in replacements.
Once again, thank you for your help.
- Tim
pin2 -IN
pin3 +IN
pin4 V-
pin5 COMPENSATION
pin6 OUTPUT
pin7 V+
pin1 NULL
pin2 -IN
pin3 +IN
pin4 -Vs
pin5 NULL
pin6 OUT
pin7 +Vs
pin8 NO CONNECT
OPA627AP
pin1 OFFSET TRIM
pin2 -IN
pin3 +IN
pin4 -Vs
pin5 OFFSET TRIM
pin6 OUTPUT
pin7 +Vs
pin8 NO CONNECT
AD843JN
pin1 BALANCE
pin2 -IN
pin3 +IN
pin4 -Vs
pin5 NO CONNECT
pin6 OUTPUT
pin7 +Vs
pin8 BALANCE
- Tim
Hi Tim
Not quite a simple yes/no but...
Stability
I don't know what the Rotel's circuit looks like, but both the OPA627 and AD843 are unity-gain stable so they should behave themselves nicely.
Note that the OPA637, for example, is not unity-gain stable and might decide to oscillate at high frequencies (depending on the circuit).
DC offset
All the opamps you mentioned are fet-input devices with very low input bias currents so DC offset shouldn't be a problem when swapping.
Bipolar input devices like the NE5532 could cause grief in that department though (depending on the circuit). btw: sorry to use the 5532 as an example, but I'm not too familiar with the fashionable new stuff.
Noise
Dunno if that's part of the reason you want to swap chips but here's the deal anyway:
AD743 is much better than AD744
OPA627 is not quite as good as AD743 but is still much better than AD744
AD843 is a bit worse than AD743
What you actually asked about
Pins 1, 5 and 8 are used differently in all these chips.
OTOH, they don't have to be used and probably aren't.
They're only for adjusting the DC offset at the output, so unless there's a little trimpot somewhere for that, they're probably not used.
If you're not sure whether they're connected to anything in the Rotel, you can cut the offending legs off the chips just to be sure (seriously!). These are pins 1 and 5 for the OPA627 or pins 1 and 8 for the AD843.
Hmm...
On second thoughts I suppose that can all be wrapped up into a short answer:
Yes - Either the OPA627 or AD843 should be fine, but cut off pins 1, 5 and 8 from either just to be safe. (and make very sure you're looking at the chip the right way up before you start cutting )
Cheers - Godfrey
Stability
DC offset
Noise
Hmm...
Cheers - Godfrey
Hi Godfrey, thanks for taking the time to provide that very informative reply.... I think I even understood most of it too
This project was published in Hi-Fi World magazine in 1994. All the details, including the Rotel circuit diagrams, are available from the link in my first post - but they mean very little to me. Would I be asking too much for you to have a quick glance at that for me to see if there are any obvious pitfalls?
No problem if not - you have been a great help already, and from what you've said, I think I'm confident enough now to try my luck with one of the alternatives if I'm unable to get hold of the AD743JN. When I soldered the sockets in place I did notice that some pins were unused, so I will check to see if this tallys up with what you said.
All the best,
Tim
All the best,
Tim
I see two choices,
1.) start on something much simpler and gradually build up your knowledge.
Maybe a passive pre-amp to develop assembly skills and recognising components and values. Then add on a +6dB gain stage to make an active pre-amp. Learn about dB and compensation and decoupling and grounding etc.
2.) insert a socket in place of the 744. and plug in your 743
Listen to how it sounds. Make the modifications exactly as AG has described.
Build up your knowledge until eventually finding why the 743 performs better than 744 in this implementation.
Do NOT modify Andy Groves' design until YOU are able to make informed decisions on what each change may do and how to ameliorate the problems.
3.) soldering in the wrong opamp alternative is not an option with your present level of knowledge.
I see two choices,
Hi Andrew, thanks for your advice, but I should probably have explained that this is a "once-in-a-blue-moon" project for me - I'm not really a hobbyist, but I do enjoy building stuff. Clearly I don't have the skills to modify this design myself, but having said that, the article does hint at trying different op-amps, so I was here for some advice on the alternatives - especially as the 743 is proving difficult to find at a reasonable price. I definitely take your point about listening to them first. As I said, I've already put in some sockets for this.
Just here taking advantage of the wealth of of expertise on these forums
Tim.
Tim.
Op-amp nulling - potential pitfall
Check the data sheet for the op-amps involved. Specifically, look at the typical application schematic - or any other application schematic that shows how to hook up a potentiometer to the NULL/BALANCE/OFFSET adjust inputs. You need to follow this exact hook-up when you use the op-amp. In most cases, you hook the ends of the potentiometer to the two balance inputs and the wiper to the negative supply. But on some op-amps the balance pot goes to the positive supply - or is wired completely differently. If you mess this up, you'll fry the op-amp. Not a huge deal, but it's pretty annoying to flush $5 down the toilet that way.
~Tom
~Tom
Thank you!Check the data sheet for the op-amps involved. Specifically, look at the typical application schematic - or any other application schematic that shows how to hook up a potentiometer to the NULL/BALANCE/OFFSET adjust inputs. You need to follow this exact hook-up when you use the op-amp. In most cases, you hook the ends of the potentiometer to the two balance inputs and the wiper to the negative supply. But on some op-amps the balance pot goes to the positive supply - or is wired completely differently. If you mess this up, you'll fry the op-amp. Not a huge deal, but it's pretty annoying to flush $5 down the toilet that way.
~Tom
Actually, I did some homework before posting above and the suggested replacement chips actually are different to the original in terms of the balance connecting to positive instead of negative.
Hence my suggestion to chop the legs just in case.
As you say - "pretty annoying to flush $5 down the toilet"
@Andrew:
Bending the pins out the way works too. Actually that's probably how I would do it, but for different reasons. The cash-strapped miser that I am, I would be thinking: "what if this doesn't work - I might want to use the chip for something else later, and then I might need those pins"
@Tim:
...I'm not too familiar with the fashionable new stuff.
D'oh - OK, so I'm that old - thanks for the reminder!This project was published in Hi-Fi World magazine in 1994...
I did follow your link - couldn't find an article or explanation for the swap, just a photo gallery. Anyway, I did find the circuit for the Rotel which shows that:
a) The chip-swap should be fine
b) The Rotel also uses NE5534, which makes me feel a bit better
Well done on putting in a socket, btw. That'll help no end with quick swaps for evaluation etc. When the dust has settled, it might be worth soldering in the chip of choice directly though (without socket) to avoid problems down the line with bad connections etc.
Sorry for bringing up the date of he article! That was probably the year I bought the Rotel, if it's any consolation
Here's the direct link, for what its worth...
PDF 14 of 17, Rotel RQ970BX HFW -Andy Grove upgrade
Seriously though Godfrey, I really appreciate this - your help has been invaluable.
Cheapest I can find the 743 for is 57GBP /pair, so I'm going for a pair of OPA627s off ebay for now (still not cheap though... about 23GBP /pair).
I don't suppose anyone knows a cheap supplier for these things ??
- Tim
- Tim
Hazard warning
Yikes that stuff's expensive!
I had a quick look at a local dealer - about 43GBP per pair for OPA627.
And the problem is... anything that expensive is worth faking.
I'd be totally paranoid that a good deal on ebay (or elsewhere) isn't the real thing.
Getting 40GBP worth of chips for 25GBP isn't such a bargain if you end up with relabeled stuff that's only worth 5GBP.
- Tim
I woudl stick with a reputable dealer like:
Welcome to rswww.co.uk
Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.
Whoops... Itchy fingers, I'm afraid... I've gone and done it now
Aha - suddenly it all makes sense!Here's the direct link, for what its worth...
I was wondering about the value of swapping the first opamp (AD744) for such a fancy component if the second opamp (NE5534) was left untouched.
Now I see the plan is to recycle the AD744 as a replacement for the 5534 - an upgrade all round.
btw: Those critters go in a lot easier than they come out. Congrats on your soldering skills if you managed to get the AD744s out unharmed. (or is there a little unplanned shopping on the side one might not want to admit to in public )
Are you doing the rest of Andy's mods as well? I see he was going for an extra 3dB gain, increasing the input stage current and upgrading some caps as well.
Regarding choice of chips, I've seen a "Best sounding opamps" thread on this forum somewhere. Might be some useful ideas there (in between the nonsense, that is).
Anyway - good luck and let us know how it goes.
Cheers - Godfrey
(hopes it turns out good)Whoops... Itchy fingers, I'm afraid... I've gone and done it now
Too late to cancel, I 'spose?
I did try there, funnily enough, but they didn't have the 627 or the 743. I'm struggling to find the 627 anywhere other than ebay in fact. All the places the come up on google seem to be distributers wanting to sell large trade quantities.
Lol! no - honestly - it's all working fine I must have a lucky touch. Lets hope that luck extends to my ebay purchases too! If not, i guess I'll have to put this one down to experieince.(or is there a little unplanned shopping on the side one might not want to admit to in public )
That's the plan. Being new to all this, i'm having difficulty finding some of the parts though.Are you doing the rest of Andy's mods as well? I see he was going for an extra 3dB gain, increasing the input stage current and upgrading some caps as well.
Will do, and thanks again.Anyway - good luck and let us know how it goes.
Have you tried these guys:? Welcome to rswww.com... i'm having difficulty finding some of the parts though.
I haven't bought from them myself yet, but they're on my (very) short list of possible suppliers.
I was about to suggest Maplin, but I see Maplin UK has gone downhill as badly as the local offshoot here. It's really sad to compare say a ten-year-old catalog with what's currently available.
I guess there's not much interest in DIY anymore - and not just wrt to electronics. "Popular Mechanics" magazine for example was all about cool stuff you can build 30 years ago, now it's all about cool stuff you can buy.
Consumer society - meh!
There is a Maplin in walking distance from my home as it happens, but the only things they stock for this project are the resistors and one of the caps.I was about to suggest Maplin
Of course, my difficulty in finding the right parts could be a lot to do with my lack of knowledge.... i.e. I'm forced to look for components which exactly match the descriptions given in Andy's project, even if there may be alternatives.
That said, I've now managed to find most of what I need (albeit from 3-4 different suppliers, and mainly consisting of shipping/handling costs ) The part I'm still having trouble with is the ZN458B. I'll keep looking.
By the way, I've just been reading this interesting thread on fake OPA627s:
fake opa627's in the wild. - Page 9 - Head-Fi: Covering Headphones, Earphones and Portable Audio
Apparently one of the checks that can be done is to measure the resistance across pins 1 and 5, but I don't know how reliable this is.
- Chip Amps
- Dumb op-amp question from complete newbie
