I intend to preorder and I'd like to be clear about PSU's options.
1. For Buffalo II without any of your IVY's, if I got the picture correct, Buffalo II can use only 1 external PSU, like single-pole Placid and whatever IVY will be used will need it's own PSU. Is that correct?
2. Or does Buffalo II requires also double-pole (+/-) PSU for AVCC?
3. There is an optional stackable AVCC shunt reg module. Is that correct?
4. The optional stackable AVCC shunt reg module can be powered either from 1 external PSU connected to Buffalo II's VD in, or from 1 external PSU connected directly to the AVCC shunt reg module. Is that correct?
5. How many external PSU's can the AVCC shunt reg module utilize?
6. What is/are the expected benefit(s) from the optional stackable AVCC shunt reg module?
It looks like both the Buffalo-2 and the IVY III has dual connector possibilities, at least where it can be done. Both 5.08 and 2.54mm connectors can be used, am I correct? Nice if you stack the boards so you can skip running wires.
Yes, that was a customer request and out new standard for input/output connectors.
I updated the web site last night to (hopefully) cover some of these questions, but here are the answers...
Yes. In standard form, the Buffalo uses a single 5V input. That feeds three onboard regulators for the digital sections, as well as the AVcc shunt regulator. Each of the supplies can be bypassed by removing a ferrite (for each) and power supplied to each's header.
No.
The AVcc module comes with the Buffalo (I am building them as we speak). It is optional in the sense that you could use something else to power AVcc if you wanted.
Yes. The AVcc uses a pin header and socket to mount to the DAC. These are not pre-soldered, so you would just not use the pin that connects the module to Vd, then supply power to the header pad externally.
I believe just one.
Lower noise for the critical analog section of the DAC.
No.
I believe just one.
Thanks Brian,
I'm still unclear.
1. Is the stackable AVCC shunt reg module included with the Buffalo II as default, or should it be ordered separately?
2. Will the stackable AVCC shunt reg module benefit from an additional PSU, separate from the one feeding Buffalo II?
3. Will there be any benefit from using external quiet PSU's, instead of the 3 onboard regulators?
I'm still unclear.
Thanks Brian,
I'm still unclear.
1) Yes its included.
2) Not in any tangible way because it is a shunt regulator that is already pre-regulated (with another shunt regulator if you use placid). It also has excellent PSRR and a very well filtered VREF.
3) Purely subjective. We are in the final stages of design for a little three pin shunt reg that will plug into each of the headers in case people want to go that route.
All of the supplies are important of course, and the approaches taken for each are deliberate, not just convenient.
The most critical supply in the cct is AVCC, and I *VERY* carefully designed the solution there. It is the result of 2 years research and development.
Keep in mind the maximum input voltage for the AVCC module is 5.5V and the minimum is 5V.
Cheers!
Russ
Also of note, although the AVCC header has four pins, only three are used by our AVCC module.
The AVCC module does not use the DVCC pin. It is there as a convenience to any who might want to use an ESS demo board style AVCC supply (where DVCC is a VREF).
Our AVCC module uses its own low noise VREF, not DVCC.
Cheers!
Russ
Cheers!
Russ
Thanks Russ,
It looks really excellent.
When the AVCC module is included, why have it on a separate PCB?
Two reasons.
1) Routing optimization. I laid it out that way because it allows me to better bypass and route the DAC board keeping critical nets as short as possible. It also lets me better layout the AVCC module itself concentrating on it as a unit. The net lengths actually end up shorter than if I had tried to squeeze it on the DAC board. I did not want to compromise here.
2) It's flexible. You can drop just about any 3.3V supply there you like. This is appealing to some DIY folks.
Cheers!
Russ
Cheers!
Russ
Must put a large warning sticker. In the past, all modules with on-board regulators were taking 5-8V
It will be prominent in the manual.
We will also put it on the web page.
Each channel has two differential opamps, how is it configured? Thanks.
Basically it is an I/V stage followed by a filter/buffer.
Is the middle power entry (PWR3) on the IVY only powering the Ballsie section?
If you do not install J1-4 yes. If you install the jumpers you only use one supply for all three sections, which is in no way to be though of as sub-optimal. Once again I was just trying to be as flexible as possible to support DIY folks who may want to try all sorts of things.
Cheers!
Russ
Can someone point me to the connectors that will allow me to skip the wires?
Just use sufficiently tall male pin headers on one side, and female on the other.
Cheers!
Russ
- More Vendors...
- Twisted Pear
- Twisted Pear Audio - Buffalo32S (ES9018 DAC)
