If you using a 75 degree waveguide tweeter with a direct radiating Mid driver, won't you have to crossover above the pistonic range if you want matching directivity? In other words you'll have midrange cone breakup in you response.
Does that seem correct?
Is there any reason you'd want this directivity pattern?
Thanks,
Dan
Thanks,
Dan
Thanks,
Dan
Dan
There is not enough information to answer this question.
a 90 degree WG tweeter can be crossed to a woofer approximately at the wavelength of the woofer's diameter to match directivity at the crossover point. Both would then be essentially 6dbs down at 45 degrees off axis correct?
Dan
Basically that is correct, yes. Why? In detail, it might differ somewhat.
Exactly what I was thinking.Basically that is correct, yes. Why? In detail, it might differ somewhat.
So why does Parts Express build a 75 degree waveguide which in my measurements are down 9 dBs at 45 degrees. My ten inch woofers then have to be crossed higher into their break-up region in order to match them. About 2.5 kHz instead of 1.5kHz for a 90 degree WG. It seems a 75degree WG would only make it harder for the DIY community to get their design right by doing this--there's a good chance the woofer's response will be rippled and have an erratic decay plus the center to center spacing at the crossover frequency will be further apart. So I figure there must be a good reason to build such a device. My guess is that it will work better in larger rooms b/c it can minimize early reflection problems. It seems that the benefit wouldn't outweigh the advantages in anything but a large have or gymnasium or if you are concerned with mastering your own score. Any other input?
Thanks,
Dan
From Altec literature...
Variable ka is the ratio of the circumference of the speaker, or baffle, to a wavelength. High ka numbers indicate high frequency. A loudspeaker will be omnidirectional starting at ka=1 and the beamwidth will halve for each octave increase in frequency. A baffle will act as a half-space baffle until it reaches about ka=2, where it makes a transistion (45 degrees on log/log graph) to 360 degrees at ka=1. Half space radiation is about 160 degrees (-6db) in real world situations instead of the 180 degrees predicted theoretically. Any loudspeaker in a large baffle is not affected by that baffle at high frequencies where the free-air beamwidth is smaller than 160 degrees or so.
Dan
Hi Dan
This is audio, logic need not apply.
Hi Dan
That's funny. I've debated audio nuts and gurus that claim just that point with me--even a manufacturer! Yet they have literature and/or design criteria proclaiming their products' and/or builds' superiority. "Just don't make sense."--Ross Perot
LineSource, thank you for that information! It is useful. I think I actually understand it. hahaha
Dan
Well my guess would be feedback rejection in live sound applications.
That's about the best I can come up with as well.
LineSource, that table very closely mirrors my measurements! Very cool!
Dan
Seems to be what most constant directivity designs are marketed for - HEY THESE SPEAKERS ARE LOUD AND THEY WONT FEEDBACK INTO YOUR SM58s AND 57s DID WE MENTION THEY ARE LOUD!!!!
I heard some of these just the other day. They were painful even at reasonable listening levels. I've got some at home at the moment that aren't bad. Not incredible, but not painful for the most part. They are a VERY rough build--well actually not built yet to any real degree. Just in the design and listen phase.
Dan
For large venues that is quite true. It has always amazed me that large CD speakers are right for large rooms and small rooms, but for completely different reasons. Who'd guess!
Different reasons entirely? I think I know what you mean, but maybe not. I think some of the reasons are the same.
Dan
Dan
Mostly different. In a large venue I want high directivity so as to get the sound only where I want it because I can't afford to waste any. In a small room I have much more sound than I need so wasting it is not an issue, but I want to avoid the room boundaries so I need high directivity. Seems different to me, but its all how you look at it I suppose.
The ability to aim the sound where it's needed and avoid VERs is what I was getting at. It's just POV. Either way I like the idea of controlled directivity.
Dan
- 75 degree waveguide, any good reason?
