Secret manufacturer?
Yes (just did not want to sound like a sale's rep.)
They are called Brownsburg Electronics and they manufacture all kind of transformers and inductors. All of there products are custom made.
I've a question regarding the possible devices used in this circuit.
What happens if JFETs with lower transconductance are used than the specified ones? Given that we're not having gain in this configuration, does it change anything but the output impedance of the buffer? Which is in the default configuration mostly dominated by the output resistor, if I'm understanding things right.
I've got proper 2sk170s available, fairly well-matched, just waiting for the caps to arrive to build one of those I'm just curious.
both the jFETs in the B1 should be sk170. That's a Pass design.I've a question regarding the possible devices used in this circuit.
I have the B1 board all populated and soldered. Now I need a power supply.
Many thanks
Lucas
I like batteries as it sounds much better to me, but a wall wart also sounds good and is very convenient. Once I stick it in a final chassis I will most likely use 3x high current 6V SLA batteries for a long lasting supply. A couple of 9V last quite a long time too, at least it is exceedingly cheap to try.
Banned
Joined 2002
diy is all about cheap, and preferred ideas will you have the batteries in the case or external ?
It will work fine, perhaps not the pinnacle of perfection that
you get with the 2SK170's, but very acceptable, as long as
you can get a few mA of bias.
most likely external, but the batteries really aren't all that big. I have a lot of Neutrik PowerCon stuff I haven't been able to use yet.
For those of you that haven't tried it, a pair of 9v batteries sounds great.
Joined 2006
How long will the battery last?
Banned
Joined 2002
Non-stop, generic alkalines @ 72-96 hours. YMMV
no activity on this projects
So, what is everyone using for volume pots ? Is the Alps Black Beauty still available ?
What are people using ?
I will be using this pot: ALPS 4 GANGS 20K AUDIO AMP STEREO VOLUME CONTROL POT! - eBay (item 380151632599 end time Dec-20-09 08:50:23 PST)
As I am building mine as a balanced unit, as far as the "Black Beauty" I still see some on e-bay at times.
Eric
Banned
Joined 2002
Eric
Thanks i saw that on there, id like to buy a VERY GOOD one, i don't want to cheap out on the pot and cap's as this buffer will be one of the key pieces of equipment.
There is always Penny and Gilles, however you will have to spend around 300$ for a stereo pot...
Banned
Joined 2002
Yeah, well im not that rich yet I fell in love with the Alps Black Beauty a few years ago, but can't find any
What value are people using 20 k?
Yes, it was the only value I could put my hands on at a reasonable price...
Banned
Joined 2002
I like the pot, i like the smooth volume control feel, maybe a slight light click but im not a fan of some of those dacts out there that kinda need muscle man to turn them.
The black beauty long time ago that i played with was exactly what i wanted.
J'
- B1 Buffer Preamp
