Hi everybody.I made a bryston 4b-7b serie in my spare time.
schematik is here : Bryston Limited - Music For A Generation
Ampfilier is very sound quality but little bass.
arkadaşım bu amfiye neyden sinyal giriyosun bilmiyorum ama giriş empendansı 1k ohm buffer kullanmassan basslarda iyi olmaması doğal kendi şemasında önünde opamp felan var 50k ohm giriş empendansı var. çok sağlam amfi
Ahem... english? ;-)
Hi!
Piercarlo
My friend wrote this.He does not know english.He says to use buffer otherwise you can not get bass.
Don't know about buffer but using PS caps will surely help.
what do you mean "PS caps" ? How many microfarads ?
Joined 2009
Congratulations, it looks like quite a bit of work went into that.
I have a Bryston, the guts of it are a 2B, and the bass is very strong (into my PMC floorstanders). What you built should have at least as much bass as mine.
So the circuit topology should be fine. That leaves components ?
Big power supply capacitors provide energy storage for the amplifier to draw on for big bass peaks so if you've got tiny caps, which it looks like from the photo, you need more capacitance on the power supply rails.
Umut arkadaşım.Öncelikle Burda bir turk gördüğüme öncelikle sevindim.
Opamp Preanfisi var.DOA 33 diye isimlendirmişler.Bu cihazı yaparken aynı zamanda crown xls 202 serisini yaptık.İkisini aynı beslemeyle aynı anda dinleyince bu anfi baslarda zayıf insan seslerinde çok iyi.Ancak crownda da bundaki insan sesleri yok. bu likde xls 202 serisi için
Bloggang.com : K_evens : C-500 Power Amplifier
Thanks for your post, but please make all future posts in English. This is an international site, so we've made the use of English mandatory in order to have the widest possible understanding.
Many thanks!
.....using PS caps will surely help.
the best joke i ever heard!
he means using MORE power supply caps..
evidence from the photo that they are too small..
you re making joke of yourself ,being so dumb..
IT HAS OPAMP DOA 33.
OTHER DEVICES compared with LOW bass.(CROWN&BRYSTON)
THis amp used 2 X 4700 MF. on power supply.
hi, mak muh
4700uF is not enough, 2 X 10 000 uF is a minimum for good bass...
anyway, you made a good work..
regards,
wahab
- bryston clone
